20 Most Recent
Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw Questions & Answers
How to replace ball bearing
depends on which one, usually you would need a bearing puller or splitter, but on some you have to crush the outer race and then use a puller to get the inner race off, that would be the fan end bearing. Let me know if you need more help
Dewalt dw718 heavy sparks at
Hello roman.... there is either excessive wear or carbon build up on the armature. If you can afford to doit time wise, I would remove the motor and have it serviced at an electric motor shop. Joe
Dewalt miter saw .
Either the blade or the guard is out of alignment. You will have to check and find out which one is the culprit.
Mitre saw blows breaker
bad cord, switch wired wrong, or bad motor. Pull the cover off the motor. Disconect the power. Sping the balde by hand and look at the bars on the comm, end of the armature. They should be evenly colored and the spacing between them should be even and clean cut looking. If there is heavy discoloration on one or two bars or heavy pitting between a couple bars the armature is likely bad.
Dewalt DW 705 wont run
Having the same problem. removed the switch and had it tested. They said it's good. Checked continuity through the cord. Good. Going to replace brushes...but then while taking resistance readings I notice the yeloo wire on the left side of switch was shorted to the white. Is that just a ground and neutral? SHoud it read that way?
HOW DO i UNLOCK MY MITER SAW TO LIFT THE BLADE AND
If all you are trying to do is get the blade arm up so you can use the
saw in the first place:
Press down a bit on the entire blade arm and that will allow you to pull
the locking pin to the out position -- the pin is on the left side
toward the rear, smallish, and shiny silver in color... you should be
able to reach out to the pin with the left hand while pressing down with
the right hand.
