Mac g4 desktop cant connect through the built in ethernet-keep getting networ settings have been changed by another application
SOURCE: I have a wireless lan connection (usb addition),
does your work have a password to log into the network? If so you may not be able to use your laptop unless they let you. Talk to your IT's at work.
SOURCE: I just purchased an old mac g4 and I would like to
OK, put them on the same network (or connect them with an Ethernet cable), turn on File Sharing on both machines, connect from one machine to the other, which gets you access to the drive on the remove machine, and then drag and drop the contents of your Desktop across the link.
SOURCE: Need a power supply for Apple Mac G4 desktop Model M7892LL/A
You could try www.applemacparts.com think they might be uk based bit you should be able to isolate what the part number is. Hope this helps.
SOURCE: how mucn memord can my Apple Power Mac G4 Dual Mac
2gb i think but mac os 9 only supports 1.5gb
SOURCE: iMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
