When i upplug the router the, device flashes green then red completly
SOURCE: Belkin router wireless is good with green lights
HI! I believe your having an issue with the connection. if the modem light is flashing. try to unplug the power of the modem for 1min and plug it back in. if still flashing, press the reset button for 20secs. then release, it will turn of and on. after it initialize, unplug the power from the modem for 20secs then plug in, if its still the same, call your isp provider. modem is dead
SOURCE: wireless light flashes red when my laptop tries to
if your using lenovo and is an Ideapad Y series or a G series Laptop look for the program called lenovo readycom in the control panel add remove programs if you have XP and if vista go to control panel and look for programs and features this goes the same with win7 just uninstall Lenovo Readycom 4.0 or 5.0 and as well look for a program called network magic if that program is present then uninstall this as well then restart your laptop, try connecting again ^_^ happy surfing ..
SOURCE: wired conections work fine...but the wireless
In Belkin routers the wireless light will be turned on Green only if you have any wireless devices is connected to the network so I belive You do not have any wireless computer connected to the routers network.
Please folloew these steps to connect to the nework,
1. Connect your laptop and the router using an ethernet cable in any one of the LAN slot
2. Open up Internet explorer and clear the address bar and type http://192.168.2.1 and hit enter.
3.You will be logged into the Belkin router setup page
4.In the left hand side under the heading wireless click on channel and ssid .
5. When its asking for password to login, leave it blank and click on submit
6. Then change the current SSID name to something else you wish and channel to 11 and click on apply changes.
7.In the left hand side under wireless click on security and then change the security mode to 64 bit WEP and when its asking for key , type a 10 digit number (only numbers) and then apply changes.
8. Then under wireless , click on Wifi protected setup and change Wifi protected setup to disabled and apply changes.
Then you can scan and connect to the wireless network in you laptop then you will be online.
I'm sure it will work.
Thanks in Advance!
With Regards,
Prema.
SOURCE: I have a Belkin Wireless
Good day,test your connection directly to your pc,and monitor,and if still looses connection ,call your provider.thanks
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
