Our Grohe K4 faucet does not have the 2 supply lines. We bought the supply lines but can not figure out how to install them. any help would be great thanks
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sink. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way.
Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging.
Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well.
Step4Repeat Steps 2 and 3 for the cold water supply line.
Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line.
Step6Turn on the water supply and test for leaks
