My pride go go elite traveler lx, has a clunking knocking sound coming from the front at every single bump I'm the pavement? I it's only 4 mths old
SOURCE: lost the main key and can't find the second key.
most keys for that type of scooter are the same, (not like a house or car key) call Pride 1-800-800-8586 for replacement or any Pride dealer can help you. Also, a paper clip can jump the ignition by placing it in their to get you around temp.
SOURCE: pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
SOURCE: we have a 11 month old elite traveler scooter. The...
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
SOURCE: pride travel scooter cut s off
Sounds like you need new batteries. Have the batteries load tested. In my experience these small 12 Ah batteries rarely last more than 8 to 12 months with an active user.
