Electrical Supplies Logo
Posted on Apr 03, 2009
Kipor 3000ti generator, doesn't start, i checked oil level, gas in the tank, pulled the choque, cleaned the spark plug,, sprayed some WD-40 in spark plug hole, generator started but stopped ? what can I do next?
  • Anonymous Mar 12, 2014
    I put a full tank of petrol and filled oil on my generator then switched it on as per procedure I then pulled the coil to run the engine it ran for 5 minutes and stopped the I could not pull the coil for 2 inch ,it is stacked ,what can be the problem?
4stevetaylor
Level 1:
Habit-Forming:
  • Contributor 62 Answers
  • Posted on Apr 07, 2009
4stevetaylor
Contributor
Level 1:
Habit-Forming:
Answers
62
Questions
0
Helped
31070
Points
97
Drain carb bowl it could have water in the gas
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1148
Points
They also have a low oil shut down which it sounds like are an issue with these models. Disconnect the wire to the sensor and try it again. You may be surprised that it starts right up.
1helpful
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
1helpful
2answers
My generator won't start. I started it when I first got it about a year ago. It's been in my garage for about a year.
Remove and clean/check/replace the spark plug first, spray some WD-40 in the cylinder, Remove all old fuel and just fill with enough fuel to run it. If you are comfortable removing the carb then it should be dipped/cleaned. Check to ensure the kill switch is not engaged/unplugged. Lemmee know then we can go further!
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
I have a Craftsman 2700 psi pressure washer with a Briggs and Stratton 850 engine (80 year anniversary special addition) . It is about 2 years old and used very little and will not start. I filled it with...
Let us know how it comes out!!
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
1helpful
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
1helpful
Kia ora, i have a makita 2 stroke grass cutter, that just wont start, checked, spark plug, fuel, took it apart and cleaned it..still wont start. Please help, it does not have model number only product...
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
After starting and operating the chainsaw for a short time, it dies and I can't get it started again. Suggestions?
Engines require 3 things. Spark, compression and fuel. And chainsaw need 2-cycle oil mixed with the gas.
Assuming you have the right oil-gas mixture and a fresh batch of gas, and you didn't leave old gas in the saw all summer long since last November.
-Take off the dirty air filter and see if saw starts without filter. Do not run without putting in new filter.
-Check exhaust port for mud dobber home or screen clogged with carbon and dirt
-See if saw fires up after squirting WD-40 directly into carburetor
-Check gas line >>> pull gas line loose and see if gas flows out of tank to carburetor
-Take out spark plug > put finger over spark hole and pull cord >> do you feel suction that says you got compression?
-Put spark wire back on spark plug >>> hold spark plug so threads touch bare metal part of spark plug hole >>> pull starter cord and see if spark shows between plug and saw >>> suggest you not hold metal part of spark plug while pulling cord [you'll understand why]
-If spark plug shows spark, then your saw has spark ... so put in new plug and start fresh.
If your saw has compression, spark, and fuel it should start unless carburetor is gummed up because gas was left in tank.
Here is the final trick. Start the saw while spraying WD-40 directly into carburetor and see if you can keep it going with the WD-40. This might take a helper. If this does not work, then carburetor is bad or gas line is clogged at carburetor. Time to take it to the shop.
I have a Onan 7.5 from 1998. only 80 hours on it. Would turn over very slow and would not start. Will not turn at all now. Fuel pump and celinoid kick in. Took out starter had it tested and it was ok. What...
If you have it for 12 years, it ran only 80 hours, it may have got rusty.
If you can open generator back cover, try to see the condition of generator iron (stator and rotor).Check the bearings.
Check the oil (level and condition, it may have water or gas in it).
Take out the spark plug and without fuel try to turn the motor manually.
If you can turn it, try to clean if any rusty parts, drain the oil, clean the crankcase with cleaning oil (make a few turns)and fill it with good new oil.
Try to spray some WD 40 or some rust remover spray where you may have rust: the generator interspace, bearing legs, through the spark plug hole etc.
Thats all I can advice now. If no result try another quiary.
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
