Two chooses:
1) you bring it to a Dewalt service center and have them do it. They will give you an estimate up front with a five or ten dollar inspection fee.
2) disassemble the unit and look for the broken part. It should be fairly obvious once you take it apart. Total disassembly of the unit is the only way to find the problem piece. Use your diagram to ensure the correct reassembly and as a added measure you can take pics with a digital camera while taking it apart. Note getting the wire routing correct when reassembling the unit is the toughest part so, take pics or notes where the wires run.
The DEWALT tool-free system ensures quick and easy changing of saw blades.
• Pull the rotating handle (10) up completely. • Unlock the handle by rotating it as shown. • Insert the saw blade into the blade holder (8)
guiding the back of the blade into the groove of
the guide roller (6). • Turn the rotating handle (10) towards locked
position until a click is heard. • Press the rotating handle halfway down
(freewheeling position) and continue rotating the
handle towards locked position. • Press the handle (10) down completely. • To remove the saw blade proceed in reverse order.
