FRIST O FALL CHECK TO SEE IF THERE IS A SHUT OFF VAULVE UNDER THE GAS TANK SEE IF THIS IS OPEN ALSO HOW OLD IS THE GAS , DONT LEAVE GAS IN THE GAS TANK THE GAS TODAY DOES NOT HAVE BUT A MONTH OF SHELF LIFE. YOU MAY HAVE TO PULL THE CARB DOWN AND CLEAN THE BOWL AND THE JETS IN THE CARB ALSO START BY PUTTING FRESH GAS IN THE TANK
If it is new and under warranty, talk to Generac about getting it fixed.
If it is old and unused, it probably needs fuel system cleaned out. Carb needs to be removed and cleaned inside and out, fuel lines need flushing, filter changed and if it has an automatic choke, it needs to be checked because it sounds like it is stuck on.
SOURCE: generac home generator does not start
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
