Kenmore 80 series- leaks small amount of water when the machine is filling up. All hoses are dry. A puddle is made from the front underneath part. I can not see where the water is coming from. Kenmore 80 series- leaks small amount of water when the machine is filling up. All hoses are dry. A puddle is made from the front underneath part. I can not see where the water is coming from.
It's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
yes there is. if you'd like go to www.repairclinic.com and enter your model number. this will show you all the parts available for your washer including repair manuals in some cases. When you get there scroll down to the bottom and where it says the number of parts for this washer click the 100(red) and it will change the page and show you 100 parts at a time. Good Luck.
I already checkout the pump and hoses and did not fine anything wrong with them. Is there anything also above the motor that has a seal that may need to be changed and if so can it be repaired ,are should I just look at getting another one?
Thanks
