20 Most Recent Kenmore 24832 Top Load Washer Questions & Answers
I put a load of clothes on to wash and left the
Did you have a small part of clothing sticking out the door? Water can leak past the door seal on this case. Other than that, run the machine empty u ntill you find the leak location.
1/19/2018 9:27:35 PM • Kenmore 24832... • Answered on Jan 19, 2018
My washing machine will not
This is a common problem and while it can be caused by a variety of malfunctions the most typical cause is a damaged lid switch. Look for a plastic pin attached to the bottom of the lid near the front opposite the hinges. The pin aligns with an opening in the top rim around the tub where the switch is located. You can attempt to manually actuate the switch by inserting something (preferably non-conductive) like a pen into the opening. This most likely will not work because the switch is probably physically damaged. To repair/replace the switch on most machines the chassis has to be removed for access.
2/15/2011 6:37:18 AM • Kenmore 24832... • Answered on Feb 15, 2011
0answers
I have a Top Load Kenmore Washing Machine. I heard
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: Ranging from easy to relatively messy but inexpensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
It's also possible that the Neutral Drain Assembly in the transmission is broken:
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Ours had a similar problem.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
All of the above sound more difficult than they really are. If you're comfortable with a socket set, pliers/vice grips and willing to get a bit dirty (oil) you can save some considerable money.
12/10/2010 7:55:52 PM • Kenmore 24832... • Answered on Dec 10, 2010
My washer will not drain.......been told it may be
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither
agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump
the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
12/4/2010 8:52:30 PM • Kenmore 24832... • Answered on Dec 04, 2010
When the washer goes into the spin cycle, the
try avoing speen cycle
11/27/2010 10:35:11 PM • Kenmore 24832... • Answered on Nov 27, 2010
Drum does not spin with
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
spinning.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
11/3/2010 7:33:06 PM • Kenmore 24832... • Answered on Nov 03, 2010
Dear sir
Your Catalytic converter element is full of fuel.
Change it - as it no longer is functioning properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/17/2010 1:57:11 PM • Kenmore 24832... • Answered on Sep 17, 2010
Egg smell when using the top loading Maytag
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/12/2010 9:54:25 PM • Kenmore 24832... • Answered on Sep 12, 2010
Leaking
back panel should not be taken off...  front 3 sides come off after top is disengaged.  water pump very accessable from there..
7/20/2010 12:55:53 PM • Kenmore 24832... • Answered on Jul 20, 2010
The washer will not spin so the water stays in
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24832200&pathTaken=partSearch
Four possibilities: (Ranging from easiest to messiest)
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
spinning.
If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
7/10/2010 12:47:18 AM • Kenmore 24832... • Answered on Jul 10, 2010
We have the Kenmore 24832 model - we started to
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to release the console for access to the pins.
I'd also check the Motor Coupler for damage:
See the following:
If the problem isn't in the switch, or the Motor Coupler the problem is likely in the transmission "Neutral Drain Assembly". Not as bad as it sounds.
See the following Whirlpool Service Manual for top load direct drive washers and their manual on how transmissions work.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
As an aside,our washer is also about 18 years old and fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
3/2/2010 11:37:29 PM • Kenmore 24832... • Answered on Mar 02, 2010
Washer won't agitate. New transmission...new timer.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
2/13/2010 8:51:01 PM • Kenmore 24832... • Answered on Feb 13, 2010
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
2/6/2010 4:26:29 PM • Kenmore 24832... • Answered on Feb 06, 2010
Washer basket not spinning during the spin cycle
This sounds like the lid switch. Will it pump the water out? If it does, it could be the motor instead.
1/2/2010 12:25:30 AM • Kenmore 24832... • Answered on Jan 02, 2010
Smelly washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
9/10/2009 2:53:30 PM • Kenmore 24832... • Answered on Sep 10, 2009
8answers
Egg Smell
We fell prey to the same desire to have the state of the art, economical and supposedly gentler on your clothing front loading washing machine. Bosch WFK 2401 and I have found a solution but it is not pretty for those of you who have a washer not hidden in a laundry room.
I keep the kick plate off at the base of the front of the washer. Using a low profile pan, an 8 x 8 cake pan is about right and immediately after every wash plase the small drain hose over the pan and open it. The pan fills about half way with water that is left in the bottom of the drain system. Doing this prevents the next load from being exposed to the rotten egg water.
It must be done at the end of every load. I too keep the front door open when not in use and pull the detergent/softener draw open as well.
Good luck. Can hardly wait to justify that I have lived with this long enough to purchase a new top loader!
8/9/2009 1:32:39 PM • Kenmore 24832... • Answered on Aug 09, 2009
Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
12/13/2008 10:49:25 AM • Kenmore 24832... • Answered on Dec 13, 2008
Front loading washer
it could be that your motor in the washer could be blowin or your belt
2/11/2008 8:25:11 PM • Kenmore 24832... • Answered on Feb 11, 2008
Kenmore 24832 Top Load Washer Logo
Popular Tags
24 questions posted
Alexander
vince
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
  • Washing Machines
