Was watching tv the other day, and all of a sudden a black bar appeared about 2/3 of the way up, and horizontal lines across most of the screen, color got distorted...think this is a y buffer problem? already took tv off wall and pulled the y buffers out...just wanted a second opinion before i order new ones...have pictures of screen if that helps...
SOURCE: Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
SOURCE: Dozens of horizontal lines across display!! HELP!!!
Bring up the menu and if the lines are not on the menu replace the small signal board that is your video prossor. If the lines are still the replace the Y main board that contrl the top half of the screen.
SOURCE: Where can I order a Y-Buffer for my Philips 42
You can try tigerdirect.com. they're known for selling really good products. Just make sure you ask them about their exchange/refund policy though.
SOURCE: I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
