20 Most Recent Philips 42PF7320A 42 in. Plasma HDTV Questions & Answers
Take the back off and try to isolate where the sound is coming from.
Philips... | Answered on Nov 24, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Philips... | Answered on Jun 03, 2017
sounds like you have a weak power board, it could be a simple fix, its mostly to be weak capacitors, that will need replacing, you need to identify the faulty ones on the power board any that are rounded topped i.e not flat when looking from the side of them, they will need replacing with the same value i.e if they 16v 33uf then replace them with the same, also if the temp is on the 85c or 100c it dont matter but its best to replace them with 100c as they can handle more heat, as power board can get hot and over time the weak temp capacitors wear out due to the heat.
Philips... | Answered on Apr 09, 2017
You can not install anything that is not specified by manufacturer. All you can do - make sure your TV have enough "breathing" room on it's back , top and sides. All Plasma Panels produce a lot of heat - it's "normal" operation. If you still unhappy with it you can put regular household fan on the back of the TV. I doubt that it would make any difference though.
Philips... | Answered on Sep 03, 2016
Contact the authorized service center for Philips. There are many reasons for this fault, and it a very skilled work to locate the fault in its main digital board. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Philips... | Answered on Jul 11, 2016
y-sustain board is at fault
Philips... | Answered on Aug 20, 2015
Hi!
My name is Chris.
I have this Phillips Wide Screen TV that didn't have or come with a remote, so I had to go out and buy a universal remote for it today from a BIG W Store. I'm having some technical difficulties & problems with switching and turning it on, but as I use the universal remote to turn on the TV, I'm having a bit of a slight problem with it turning it on, Ok, Yes, it works and Powers on, but there is nothing showing or giving me the indication that there is no picture or sound showing up on this Wide Screen Phillips TV, But there is a little red & green light at the bottome right hand corner that keeps on flashing red when ever I use the universal remote to switch the power on. Is there a possibility, that i can get some help on here, to help me out with any suggestions, is to why I'm not getting any picture or sound showing up on this TV with this universal remote ? Is there anyway that i can maybe get some help with this to help me out with solving my issue with the Phillips Wide Screen TV ?
Philips... | Answered on Jun 11, 2015
It is normal. There is no fault with your TV. Its high frequency response is too god, that is why you do notice it. Try by reducing the Treble, in the audio setting. Gopakumar Gopalan Google
Philips... | Answered on May 22, 2014
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Philips... | Answered on Mar 26, 2014
Philips 42PF7320A 42 in. Plasma HDTV Logo
280 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
volumn increases randomly wont turn down
  • Televison & Video
