Most likely you can swap the phones. On older systems it might not work so I would try one first. You do gain extra buttons which can be programmed as desired. Any buttons you had on your M7310 would be on the T7316e. You can check the buttons by pressing Feature *0 this will allow you to check any button on the phone.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
