Please note that the codes programmed into the remote will probably not operate devices that are newer than the TV. Sometimes electronic devices that were released less than 6 months before the remote was programmed will not respond to the available codes in the given remote.
If you are trying to find a Samsung TV code that will work with another remote, please indicate which universal remote you are trying to program. (There is a Redi-Remote replacement for the BN59-00599A that does not function as a universal remote.)
Your question is not quite specific. I understand you are using a Samsung TV Remote Control on your Panasonic and Blu-Ray If it isn't operating correctly you should check the code you've used and try some other code from manual. If don't get a better operativity, you should buy the original remotes of your blu-ray and your Panasonic.
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
your rca does it have a button for cable. then you can program your tv remote to work with the cable box. go to the manual and try all the codes for rca tv. if this does not work then you have to try it manually. have them give you a different adapter. it might be in the box or remote.
Problem solved. I decided to use the learning function of my remote to learn the wanted commands of the original remote. The remote I used was a Sony RM-VL610 which could learn the original remotes functions easy and quickly. This is a very good remote for only $30 purchased at Target. The Macro commands were also entered rather easily. I did not try this method originally,because I thought it would be too time consuming and difficult. pcwg
If there are no codes listed for durabrand, look to see if the remote has the ability to do a code search. If not it may not operate your TV. If you want the original remote contact remotes.com
usually the universal remote comes with a code book. if you're TV is not on it the remote won't work. But most TV's are on there. If you can't find the TV, go to the ORIGINAL COMPANY of the TV. (RCA, Samsung, etc.)
