20 Most Recent Samsung BD-P1200 Blu-Ray Disc Player Questions & Answers
2 ways to update Vizio BR vbr220, see page 41 of manual
1. via USB
2. via internet
Via USB
1. Download the software from www.vizio.com to the root directory of a USB thumb drive.
Notes:
The USB storage device should be 1GB or larger with at least 100MB of free space and
formatted FAT32. NTFS and other file systems are not supported.
The USB storage device must not have other .iso or .dat files in the root directory.
2. Connect the USB storage device to the USB port on the front of your player.
3. Follow the on-screen instructions to update your player.
Via Internet
When a new software update is available, a message will be displayed on the Home menu. To
update the software:
1. Connect your Blu-ray player to your home network
2. Press the B (green) button.
OR
a. Press < or > to select Settings and then press SELECT.
b. Press < or > to select System. The System menu opens.
c. Press \/ to select Update Via Network and then press SELECT.
Samsung BD-P1200... | Answered on Jul 08, 2014
Firmware update is a skilled work, especially to Blu-ray players. You should know well about which firmware version is now installed with your player, before updating it. Without knowing this, never try to do anything. It might make the set unresponsive to any external commands. Contact the authorized service center for details, and more assistance.
Gopakumar Gopalan Google
Samsung BD-P1200... | Answered on May 31, 2014
hi,
Try any one of the following code.
20490, 20573, 20820, 21075, 20899
Progarmminig procedure
The AV1 and AV2 switch position can be used to program a
VCR, DVD, STEREO, 2nd DIRECTV Receiver or 2nd TV with
the following instructions.
1. Turn on the component (e.g. DVD Player) you wish to
program.
3. Move the slide switch under the AV1 (or AV2) icon.
4. Press and hold the MUTE and SELECT keys at the same
time until the green light under AV1 (or AV2) flashes
twice and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of component being programmed. If performed
correctly the green light under TV will flash twice.
6. Aim the remote at your component and press the power
key once. The component should turn off. If it does not
turn off, repeat steps 3 and 4 trying each code for your
brand until you find the correct code.
7. Repeat steps 1 through 6 to program a new component
under AV2 (or AV1).
ok
Samsung BD-P1200... | Answered on Feb 21, 2011
For my Vizio 3D 55 inch I used the code 119 on my Samsung Blu-ray HT-C6600
Samsung BD-P1200... | Answered on Feb 19, 2011
It could be it needs new firmware.
If you have not updated firmware it would be worth doing this as there have been quite a lot of updates on most players.
Also make sure the disk is perfectly clean.
Please dont forget to vote if you liked my answer
thanks
Samsung BD-P1200... | Answered on Feb 09, 2011
First check if your DVD is compatible with the disc, if it is compatible and is not playing, then it means your lens is either weak or bad.
Try to use a lens cleaner on it and if it does not work, then you replace the lens with a new one.
Replacing the lens is easy, all you have to do is get a replacement lens, then you open up your DVD player, with the appropriate screwdriver, locate the lens and replace it with the new one you got for it.
Take care and good luck
Samsung BD-P1200... | Answered on Dec 27, 2010
When you disconnect the power you need to leave disconnected for 40 min, so the electrolytes caps can dissipate, and then the processor will reset back to normal.
Samsung BD-P1200... | Answered on Nov 24, 2010
Samsung BD-P1200 Blu-Ray Disc Player Logo
69 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
  • Samsung Televison & Video
Most Popular Question
not reading any dvds
  • Televison & Video
