Ok to start you do not need a manual to activate the power switch on the mainboard. If you take a flat "standard" screw driver or like tool and gently go along the chasis "tower" connectors on the mainboard you will be able to find the -/+ for power. Brush against the mainboard connectors two at a time and the board will power up when you brush the correct two. When you find them take the correct chasis pin and slide it on as PSW "power switch" If you do not get power up at this point and you know the power supply is good most likely the SB "south bridge" of the mainboard is bad. That being the case you will need a new board. When you have power from the power switch yet it will not send power to the CPU then the NB "north bridge" is no good again meaning a new board. You can buy a power supply tester at any large pc outlet store under $25 usally. Hope this helps and good luck.
VGA Driver
U can download ur manual from http://www.motherboard.cz/driver/
Buy another one,like me!!!!
Nowdays, you can find those motherboard manual online. Asus k8n-dl. Asus should have the manual in pdf format.
What type of motherboard ur using like ?(make and model number of motherboard)
Hey i found a site with the manual! check here http://www.tqm.com.uy/soporte/manuales-de-pcchips.htm its in spanish but just look for the m863g v1.5 thing Hope this helps!
I have had 2 of these MotherBoards do the samething. I had to replace them. it seems they only last about a year or 2.
Http://www.asrock.com/mb/manual.asp?Model=775Dual-VSTA&s=n There's your manual.
What motherboard do you have?
Looking for the user manual for a matsonic ms8137c+
SOURCE: motherboard
do u have pw switch on right pins power p start with red on that oen go over one to conect the black try both ways never up down on pins tho side to side only ok
SOURCE: motherboard
I have one sitting in front of me , unfortunately I cannot get it to you but will be happy to tell you the positions. It's not very difficult to fix and I will stick by until you get it correct. I hope I don't complicate this in an attempt to keep it clear and don't be insulted by my answer. I am guessing you don't have a great deal of experience working inside the box and it can become confusing. This is much easier than the length of this answer suggest. You will do this in about 30 seconds, move anything that is in you way and make a note of where it came from. If your hand is small you are lucky but don't force anything and if you are pushing on anything trying to get down there see what it is before pushing more. Better to move it.
There is a front panel connector that is on the bottom right of the board if you orientate the board by placing the computer access panel in front of you with the front of the computer facing to your right. Then right below the floppy disk controlled socket (the smallest flat cable in the box) if no floppy the empty socket below the battery.
There is a double row of pins, looks like 2 rows of 10 pins each. Mine are multicolored, pink and green etc. and the should be marked + and minus, at least plus. The number 1 pin is on the left. The 1 pin is actually the bottom left and the 2 pin is above it. Back down to the bottom row and pin 3 is right next to 1 and the 4 pin right above it. Pin 3 is the second pin on bottom left. Follow the way it goes? The bottom is 1, 3, 5, 7, 9, 11, 13, 15, 17, 19 and right above 2, 4, 6, 8, 10, 12, 14, 16, 18, 20.
Pin 2 is + so put your Power SW on pin 2 and 4 with the colored wire on pin 2. Colored wire in the pair should be positive, and it can be blue, red, green, mine is red and white.
The Power LED goes right next to the Power SW on pins 6 and 8, the colored wire on pin 6, mine is blue and white. And finally the HDD LED goes on pin 7 and 9. All counting from the left to right. My pins are not marked as I think its not critical how the LED is connected and if it does not light then reverse those 2 pins. My colored wire is on pin 7 and its blue. May as well finish, the Reset button is wired to pins 17 and 19 with 17 being positive and the speaker if you have one hooked up (your tiny internal speaker not for listening to music) is a 4 pin connector with the middle 2 sockets empty and fits over the last 4 pin s on the bottom right. 13, 15, 17, and 19. Pin 13 is +. There may be other wires but I don't know where they go depends on what they are but this is what you need. Good luck. And make sure all is unplugged and touch the box to ground yourself or wear a strap. Look but don't touch is a good rule for now.
SOURCE: motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
How can I plug my motherboard?
I have a "EP-8KTA3L+" m/board and after unplugging ana replugging the speaker and switch lead it wont power up. Can any body tell me where I can find a copy of the manual for it. I get one long and two short beeps as it tries to power on and that is it.
i unplugged my power supply, speaker, led display all from the mother
board and now my computer won't power on i need a manual for my mother
board
I have a "p4vxasd2+" m/board and after unplugging the sw lead ,hdd lead,reset sw,power sw i cant conect it back. Can any body tell me where I can find a copy of the manual for it.
I have a AOpen MX46L motherboard will not bootup, when powered no monitor or key lights on but there is a sound from the speaker,
im 15 and building my 1st computer i got given an Albertron KX600s Pro for free from a friend but he he had lost the manual for it i have searched the internet for hours trying to find one on-line to no avail
i need to know what all the plugs are and where the :
-reset switch
-hdd led
-power led
-power switch and speaker goes and witch way they go around and all this info should be in a user's manual
a
Power supply unplugged from my motherboard. So please give manual of this motherboard.
My PC will only blink on for a half-second when I turn on the power.
When I remove the JATXPWR2 ATX Power Connector which provides +12V to the CPU power circuit the PC boots up. When I plug the 4-pin power connector back in, I still get no response from the PC.
I don't know if it's the problem is PS, CPU or MB (or other). Any help would be GREATLY appreciated.
I have a p3 500 and replaced the chip with a p3 933 chip now monitor wont wake up help me pls
i unplugged all the wires from my mother board to install a heatsink for my cpu because to do so i had to remove the mother board. Now that it is installed i dont know where the plugs go back in and i dont know where my manual is. so i need a new one.
replaced a MS-7184 MB with the FOXCONN 761GHK8MB-RS on a HP Pavilion a1250n. On the MS-7184had a HD not connected after a earlier wavy herringbone screen on video. HD was OK in other PC. Replaced power supply, now the motherboard.
After installing the 761GHK8MB, nothing turns on, no LED, no fan on power supply, zip. Reconnected old MB with just front panel jack & 24 pin power jack and turns on OK, power supply fan on, LED lit.Dissconnected CPU power jack, no change. Am I missing an interlock?
The 1394, comm, aux jacks not connected (no place to connect). What am I missing?
Help!!
I have a hp computer needed to get at the power suply this ment removing motherboard undone all conections now cant remember where they go back board made by msi "ms7184" can you help just power switch and leds. thanks Paul.
jumper
compaq presarip SR181ONX COMPUTER
ms-7184 mother board.
NOW THE COMPUTER JUST BEEPS?COULD IT BE THE POWER SUPPLY NOT WORKING CORRECTLY? S IS THE MOTHER BOARD NO GOOD?THE MONITOR SAYING NO VIDEO SIGNAL?
I unplug the power switch, led, hdd led, and reset switch and forgot the placement of each, my motherboard is MSI KEN NEO 4 can you please help me?
power connetion
i have biostar 865gv micro 478 main board 5 nos.this all main board are no power on pls give me a solution for this problem very urgent
i unplugged the power switch from my mother board and i can not connect it bach.Â
