20 Most Recent Intel Desktop Board D845WN Motherboard Questions & Answers
Intel D845 manual
7/7/2015 4:35:14 PM • Intel Desktop... • Answered on Jul 07, 2015
Download Intel D845WN Motherboard Drivers
go to intel download drivers support type in board then download ok
10/26/2013 7:11:18 AM • Intel Desktop... • Answered on Oct 26, 2013
2answers
Data lost
check ur HDD another PC....
and make sure hidden file are showing....
9/25/2013 2:21:11 AM • Intel Desktop... • Answered on Sep 25, 2013
3answers
Doesn't start
hi i got biostar g31d-m7 motherboard dual core cpu 1 gb ram 500gb hard it wont boot just stucks in windows logo screen and cant even reinstall windows its just stucks in the booting logo
6/22/2013 4:53:01 PM • Intel Desktop... • Answered on Jun 22, 2013
Need draviver video & sudio for D845gebv2/d845pevs
Try here: Intel
1/30/2012 11:28:10 PM • Intel Desktop... • Answered on Jan 30, 2012
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
12/17/2011 2:37:49 PM • Intel Desktop... • Answered on Dec 17, 2011
Intel desktop board d845wn front
Hi, here you can read info and download drivers
for your mainboard:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845wn
The pin layout look like this:
Connect: 1 and 3, 2 and 4, 5 and 7,6 and 8.
The 9 number is not in use.
Its also printed in on the mainboard with very small letters.
9/20/2011 3:48:32 PM • Intel Desktop... • Answered on Sep 20, 2011
4answers
Sir, my motherboard has problem that its display
Its may b the problem of ur VGA or processor so 1st of all chek ur VGA
9/17/2011 2:20:37 PM • Intel Desktop... • Answered on Sep 17, 2011
2answers
Hi sir; I have
You may be able to upgrade the BIOS firmware so it can support USB 2.
You can download the motherboardBIOS upgrade and device drivers from Intel WEB site. Select your
model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers
thatmatches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
4/29/2011 9:27:34 AM • Intel Desktop... • Answered on Apr 29, 2011
Window x p setup very slow, SDram256 Opreting
You are using really slow RAM, SDRAM 256 should be upgraded to a 512, 1024, or so. Upgrade your hardware and you should get satisfying results.
3/23/2011 10:05:09 AM • Intel Desktop... • Answered on Mar 23, 2011
Sir,My system already formatted,than i
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
3/18/2011 6:23:05 AM • Intel Desktop... • Answered on Mar 18, 2011
3answers
I haven't driver
here : http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845WN
3/5/2011 9:35:53 AM • Intel Desktop... • Answered on Mar 05, 2011
2answers
Need to know which plugs
Consult the manual. It's different for every motherboard. Usually the purpose of the plug is printed on it, and the motherboard usually has the pins labeled on the motherboard. Again, usually, the plugs go in with the text facing "out" (that is, the sides without the text on them go against each other).
Here's your manual: http://downloadmirror.intel.com/15334/eng/D845HV_D845WN_ProductGuide01_English.pdf
3/1/2011 1:52:41 AM • Intel Desktop... • Answered on Mar 01, 2011
How to download sound driver for D845PESV system
Press Accept or replay
I have a solution for this
Bruce
1/14/2011 4:05:27 PM • Intel Desktop... • Answered on Jan 14, 2011
D845wn motherboard when i turn
??? please repost your question
12/2/2010 11:30:33 AM • Intel Desktop... • Answered on Dec 02, 2010
When we system start then after some time system
Make sure that your RAM is high enough, at least 512, and your processor speed high too, like at least 1.0. If so have system formatted. Low resources, as shown above could cause it or errors in the OS (operating system). If formatting does not resolve it it means your may be having bad sectors in your hard drive. Try then changing the hard disk.
10/10/2010 2:40:19 PM • Intel Desktop... • Answered on Oct 10, 2010
0answers
2answers
Water in mainboard
Replace the motherboard. There are 90% chances that your motherboard is toast.
Cheers
8/5/2010 9:15:27 AM • Intel Desktop... • Answered on Aug 05, 2010
Intel Desktop Board D845WN Motherboard Logo
96 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
doesnt start
  • Computers & Internet
