Electrolux EW1000i Front Load Washer Logo
Posted on Mar 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot start or change cycle panel. Can you help please. karen
Anonymous
Level 3:
President:
  • Master 1,294 Answers
  • Posted on Mar 30, 2009
Anonymous
Master
Level 3:
President:
Answers
1294
Questions
Helped
901155
Points
3465
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
My hoover washing machine stopped working but is displaying padlock symbol but the padlock isn't locked correctly and it's not opened as well
The padlock symbol on your Hoover washing machine indicates that the child lock feature is activated. This feature is designed to prevent children from accidentally starting the machine or changing the cycle during operation. If the padlock symbol is displayed but the padlock is not locked, it's possible that there's a malfunction with the child lock system.
To resolve this issue, try pressing and holding the "Start/Pause" button for several seconds until the padlock symbol disappears. If this doesn't work, try unplugging the machine from the power source for a few minutes and then plugging it back in. This may reset the machine and allow you to deactivate the child lock.
If neither of these solutions work, consult the user manual or contact Hoover customer service for further assistance.
Hi my front loader tumble dryer is displaying a locked padlock symbol and it is not doing anything The last cycle is showing but nothing is happening Help
A padlock on the display means that the child lock is activated. This function prevents kids to play with the appliance. The cycle cannot be either started or changed accidentally, while the machine operates. The method for deactivating the lock varies from one appliance to another.
Read users manual how to reset it
When i Press start the washing machine clicks a few times then red padlock light comes on. Door interlock changed but still happening. Any help appreciated.
I gather that the interlock has been replaced and now the padlock symbol lights up plus some clicking. I think the clicks are the door lock engaging and the padlock just shows this. Do the clicks continue? Does the door stay locked? If so I believe you have a fix.
Why washing machine display shows padlock?
this symbol means that the lock is on for the controls. this is a feature so that nobody can use it (childproof) If your machine comes with that feature. if not then it indicates your door is locked
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
1helpful
Symbol showing on display
you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual
1helpful
2answers
My Bosch Classic 6 is dispalying the key symble and will not let me proceed with the washing cycle thank you
When the machine is on, and the key symbol is showing, push and hold the start button for 5 full seconds to turn the child lock off. Holding the start button also turns the child lock on if it is not already on (it is a toggle switch).
How do i get the channels to change on vx10 radio selector does not seem to change them radio recently repaired by yaesu and user manual not much help
The dial is probably locked. Look for a little padlock symbol on the display. Check the user manual for Dial or keyboard lock. Generally on Yaesu radios you use the function key plus a keyboard key. If the keyboard is labeled, you should see something that looks like a padlock next to the correct function key.
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
