My Thomson S46-55 washing machine spins BUT does not drain the water (clothes still heavy with water at end of cycle. I always use the 40 degree water heat and select number 4 for the wash. To try to get it to spin properly I then try to move the clock to 13 and 14 function. I have no option but to take the clothes out dripping with water, can you help?
Jacqueline
It could be that the filter needs cleaning, or possibly an uneven load
Check to see what is the story with motor and belt tht turn drum and extract water. If belt has stretched it needs to be replaced. Search Over 2 1 Million Appliance Parts
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below)
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
