Why does the mousse come out of the tin in a liquid form after only useing it for a quarter of the tin . yes i have shaken the tin and turned it upside down and my daughter also tried it but it still
L liked this product until this problem started and now l think I wasted my money
There are a lot of factors. It would be helpful to see the recipe.
You could be using the wrong amount of baking powder, or nun at all
Are you using self rising flour
Your oven may be the wrong temperature.
no you this is not a good design you first use mousse at night to go to sleep or 3 hour before bath then you use your spry for more health info http:www.homeoinformation.blogspot.com
did you use anything like a liquid varnish remover when cleaning the table prior to varnishing it? if so then i`m afraid you didnt clean all of it off and the varnish is failing to harden
if you didnt then is the varnish an old tin? if not the you might have got a dodgy tin from you dealer take it back and explain the problem
If it has been shaken or tuned over, then the liquid has mixed with the wax, which is why is doesn't circulate. You may be able to fix this by turning the lamp on until the lava starts to break up, then turning if off and letting it cool. Repeat this up to six times to get the liquid and the wax to separate. However, it may be irreversible.
You should always put a spoon in a cup of liquid that you heat in a microwave oven. The microwave with a potato wrapped in tin foil is like operating the oven with nothing in it! If the microwave was spotlessly clean then your in trouble. 1 put a cup of cold water in the microwave and set for 5 minutes. if the water boils then your lucky if it cold then go and buy a new microwave and stop your childs allowance for a fortnight. One might ask the question how old is your child and should they be using such a machine unsupervised!
What "form" are you using? liquid, gel, powder? try using a different type and lean towards the more liquid forms if your washer can handle them, ie move from powder to gel or liquid, and from gel to liquid. Hope this helps.
