SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
SOURCE: Manual for Jabra BT150 ????
You can download the manual & get other information from the link below: http://web.jabra.com/JabraCMS/EM/EN/MainMenu/Support/WirelessHeadsets/JabraBT150/ Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Jabra A7010 BT hub will not pair with Sprint BT headset
Have you tired to pair your hub with any other non-Jabra headset? I am trying with Plantronics Voyager 520 without success ;(
SOURCE: Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
SOURCE: cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
