Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Logo
Posted on Mar 27, 2009
Distorted audio into AG_DVC7 Digital camera from Mixer Aux send
My Ag_DVC7 Digital Camera will not receive clean audio from the Aux Send from the mixer. (Mackie Mixer). If I have one person speaking, it's ok. Singing from a group---distorted. Turned down GAIN in camera...still no help
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Aug 10, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
Helped
6435
Points
33
Set the camera audio switch to line, not mic feed. This switch is on the camera. Adjust the audio gain to -60db in the menu settings.
2helpful
I need USB driver of Panasonic AG MX- 70 switcher
Ineed also usb driver for panasonic digital AV mixer AG MX 70, please send to my mail [email protected] if you can help me.
Thanks
No playback just blue screen
sounds like the dvc7 needs a cleaning tape.
Horizontal stripes on play back
the stripes are caused from one of the heads on the dd cylinder not updating. you need to stick a head cleaner in, if that does not solve the problem then either the head is going need a thorough clean or it is damaged. it will need replacing.
AG-DVC7
take the tape out of the camera. you don't need to put a tape in the camera if you are not recording in the camera.
Tried all advices but no solution...
cleaning with rubbing alcohol may have aggravated your problems - rubbing alcohol contains glycerin, which may tend to worsen the connections. to clean the connectors, use only _denatured_alcohol or electrical contact cleaner. the only connectors I have had to clean are the two leading to the video head.
1helpful
2answers
Panasonic AG DVC 20
check beneath the fold-out LCD screen.
Ag-dvc7
most likely cause of this problem is loose or dirty cable connections to the video head or mechanism in the camera. get a tech to disassemble the cam and check the flex cables connecting the main board to the mechanism. same fix is good for AG-DVC10 and AG-DVC15.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
