Power turns on and door on DVD opens and closes, but it will not play DVD's. I don't know if this will be an issue in fixing the problem, but there is no remote control. Thank you for any help that you can give me.
If the door does not close either something ( a coin or anything) got inside or there is a issue with the mechanism= alignment or possible bad part in that mechanism that loads and positions the disc.
A suggestion when door opens try to take a quick look inside with a flashlight to see what you can.
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommendreplacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
