20 Most Recent Sony CDP-CX400 400-Disc CD Changer Questions & Answers
No power
Is the unit dead completely?
1/6/2017 2:33:16 AM • Sony CDP-CX400... • Answered on Jan 06, 2017
Change Drive Belts on Sony CDP-CDX400
You need to change the belts???
1/6/2017 2:31:44 AM • Sony CDP-CX400... • Answered on Jan 06, 2017
0answers
Getting Loading Error on screen
Could be bad drive belts in the table mechanism. Have to take the top off and take a look inside
1/8/2016 6:24:13 PM • Sony CDP-CX400... • Answered on Jan 08, 2016
My Sony 400 cd player will not play any cd's.
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
1/2/2016 5:23:49 AM • Sony CDP-CX400... • Answered on Jan 02, 2016
I currently own a Sony-400 CDP CX400, i was wondering if the remote control for my CX400 is compatible with the cx455, I also wanted to know what is the major differences in these two products?
just use the remote and if it works then it is compatible many companies use the same remote frequencies between models as it saves on expense of producing new units there may be a problem if the newer unit has extra items to remote control
10/10/2015 11:02:45 PM • Sony CDP-CX400... • Answered on Oct 10, 2015
Disc will not load
2 belts wear out on this model. Replace them.
8/25/2015 9:02:39 PM • Sony CDP-CX400... • Answered on Aug 25, 2015
Disc will not load on sony cdp cx400
Loader mechanism fault. Not engages the CD properly to desired tray section. Contact any service technician. The loader tray should be repaired, and this is not a user repairable fault. http://electronicshelponline.blogspot.com/
10/17/2014 3:39:16 PM • Sony CDP-CX400... • Answered on Oct 17, 2014
My Sony CDP-CX400 player door will not open nor will the cd 's move or play.
Power supply problem?
8/9/2014 8:40:07 PM • Sony CDP-CX400... • Answered on Aug 09, 2014
I have a Sony CDP-CX400 that has a flashing blue light.
sounds like the mech may be out of alignment. I would try running it by hand and making sure everything is moving correctly.
3/27/2014 2:27:43 AM • Sony CDP-CX400... • Answered on Mar 27, 2014
I have a Sony CX400 & the belts became old & loose. I can easily see the TWO belts that are the same (called rorary belts) part # 422587601. My problem is there is a third belt that I cannot s
I was under the impression that the third belt is a larger belt that rotates the carousel, and it is located under the carousel -- so you would have to lift/remove the carousel to get to it (which would probably give you some new problems). I could be wrong about this, but that's the impression I've gotten from everything I've learned about the CX400. If you're having problems with your unit, the third belt might NOT be the cause of it. If you're not having problems you'd probably be better off leaving that third belt alone. Best of luck to you. Hopefully somebody else will chime in with some useful info.
3/26/2014 2:38:38 PM • Sony CDP-CX400... • Answered on Mar 26, 2014
3answers
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
2/26/2014 12:55:33 PM • Sony CDP-CX400... • Answered on Feb 26, 2014
0answers
0answers
Table error
Be the first to answer 1/25/2014 2:55:37 PM • Sony CDP-CX400... • Posted on Jan 25, 2014Be the first to answer
Sony CDP-CX400 400-Disc CD Changer Logo
64 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony cx400 amp belts became old amp
  • Audio Players & Recorders
