20 Most Recent
Sony Walkman NWZ-S616F MP3 Player Questions & Answers
Where and how do I uplaod movies to my walkman nwz-s616f
Download any video converter, its easily found on google. after downloading your movies, drag them into your any video converter on the top right hand side of the any video converter change profile to Customized MP4 movie, under that they'll be video options, i use as follows an it works perfectly,
Video Codec: Xvid
Video Size: 320x240
Video Bitrate: 768
Video Framerate: Auto
Audio Options,
Audio Codec: aac
Audio Bitrate: 128
Sample Rate: 4410
Audio Channel: 2
Disable Audio: No
A/V Sync: Default, be careful when downloading Any video converter, sometimes when you download it it only lets you convert 3 minutes of it try downloading fron a differtent site it completely free!!! and for the best Movie downloads for free go to www.pspiso.com sign up then go down to PSP format movies then movies, then scroll down and pick any of the uploaders, then go to the last page there will be a list of movies good Luck :) email me if theres any problems ill be glad to help :)
[email protected]
Cant transfer a playlist to my sony mp3 player
Windows Media Player (WMP) 11 in XP does not create Playlist on my MP3 MTP device. I have a Sony Walkman NWZ-S544 but I think my problem and its solution could also apply to other MP3 players that don't receive Playlists from WMP. And perhaps to Vista and Windows 7?
When I connected my WALKMAN to my PC and used WMP to Sync (transfer) Playlists to it, the songs were correctly Synched but no Playlists were created on my WALKMAN. My problem was that Windows had installed the wrong driver for my WALKMAN. Here is how I diagnosed and fixed the problem.
DIAGNOSIS: When I used WMP to Sync, the picture in WMP's right hand window was a generic MP3 device. It should have looked like my WALKMAN NWZ-S544. When I looked at the device drivers, I couldn't find a driver for my WALKMAN NWZ-S544 under Portable Devices, but instead found a non-MTP Walkman listed as a USB Mass Storage Device. (See Fix explanation for how to look at device drivers.)
Fix: To fix the problem I first uninstalled the incorrect driver and then installed the correct driver. Here's how…
- I disconnected all MP3 players and USB devices (Key/thumb/External Hard drives, etc) from my PC.
- I opened the Device Manager. Right-click My Computer-Click Properties.-Click Hardware Tab-Click Device Manager. No Portable Devices were showing. Click the + to the left of the Universal Serial Bus Controllers heading and there was one USB Mass Storage Device but it was for an irrelevant memory card reader on my PC that I can't disconnect.
- I connected my Walkman. Looking at the Device Manager, I see that one new USB Mass Storage Device is now showing, I right click-Properties and it describes it as a Compatible USB storage device (Walkman). This is my problem. Windows is using an older Walkman driver. My Walkman driver should be for a MTP device.
- I again right click the Walkman USB storage device and click Uninstall. I click OK to Confirm Device Removal. The Device Manage no longer shows my Walkman which has now turned itself off.
- I disconnect my Walkman and then reconnect it. Windows gives me the message that I have installed new hardware. The Found New Hardware Wizard starts. I click "No, not this time" and then Next. I click "Install from a list or specific location (Advanced)" and then Next. I click "Don't search. I will chose the driver to install." and then Next. I click "Show compatible hardware" and I select "MTP Device" under Model and then Next. Windows then finds the appropriate driver for my Walkman and I'm done.
VERIFICATION: To verify that it is properly installed, look in the Device Manager under Portable Devices (while your Walkman is connected). Click + and you should see:"Walkman NWZ-S544". Or simply look under Name in My Computer and you should see an entry for Walkman NWZ-S544, and an icon that looks like your Walkman. Everything should now work properly.
How do I load a dvd onto my walkman.
First off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it loads them onto your mp3 player as long as it?s connected, this program will also allow you to download YouTube videos and put them on your mp3 player too.
I accidentally deleted the PICTURES
There is a way to you may get back those deleted picture files from your MP3 MP, BUT it is just possible. Because if those deleted files has been overwritten by new files you saved in, then there is no hope. However usually overwritten cases are hard to happen as long as your MP3 has enough volume.
Then, take so called data recovery program to handle the issue and see if you can grab some or all of the deleted files back. Have a try of
Wondershare Photo Recovery. with both Windows and Mac versions provided.
If you are running
Windows, go to
video photo recovery program.
If you are using
Mac OS X, turn to
Mac photo video recover software.
You should take care - before your files are recovered, do not save more files to your MP3 in case overwritten situation will happen.
Sony Walkman SUDDENLY won't connect to my computer
What you can try doing is to uninstall the driver that the computer has installed for it. To do this, right click on My Computer/Computer (depending on your OS it has different names) click properties, and then manage. Once that opens, on the left menu, select Device Manager. From there, plug in your MP3 player, double click to get to its properties, and then uninstall it. restart your computer, and hopefully that should fix it so you can get into it and format it. If you have any problems, repost and i can try helping you more.
Sean Huffstickler
My Sony Walkman NWZ-S616F just suddenly stopped
you can charge your walkman onto your cable box (if own one) and download music and videos off of youtube. Go into my documents and type in brand name into files and it might recognize it.
How do I get the battery out to replace. player
Hi chasruthdorm,
The battery can be changed only at Sony service centers, as per the manual. Please take it to a nearby Sony center to evaluate if you indeed need a battery change, and get them to do it right away.
