I've had my Rotel since about 2005 and just the other day the Rotel stopped working. The standby light is illuminated and when I turn it on (remote or receiver) it clicks, turns off and goes back to standby. I'm not sure where to start to diagnose the problem and would appreciate any help. I'm located in Deerfield, IL and not sure if there are any recommended dealers I should check in with.
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
SOURCE: Hi, I have a Rotel 1050 receiver that I am trying
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
SOURCE: Hi i have a Rotel
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
SOURCE: not playing in stereo
You have blowin a IC in it, Power amps are not suppose to be use for the purpose you were useing it for.You are dam lucky they didn,t go up in smoke.
