20 Most Recent Marshall Amplification Marshall Cover For Dsl401 Amp Questions & Answers
After a gig last night we tried our Marshall JCM
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
9/11/2011 1:00:02 AM • Marshall... • Answered on Sep 11, 2011
Marshall troubleshoot
First check the preamp valve in that curcuit
11/3/2021 6:47:15 AM • Marshall... • Answered on Nov 03, 2021
Can I use the speaker from the marshall mg30cfx with a marshall dsl15h?
Hi. Doesn't look like it as the speaker is a 4 ohm one and the head needs at least 8 ohm as far as I can see.
10/28/2021 5:24:26 PM • Marshall... • Answered on Oct 28, 2021
MARSHALL G15MS AMP OWNERS MANUAL
https://www.manualslib.com/manual/99237/Marshall-Amplification-Mg15msii.html
1/17/2019 10:35:23 AM • Marshall... • Answered on Jan 17, 2019
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
1/8/2018 4:34:06 AM • Marshall... • Answered on Jan 08, 2018
Marshall valvestate 8080 experiences volume surges. Seems randoms as occasionally it won't happen or it will happen less than other times. But all the same annoying when playing! I get rid of i
Most likely cause for this is an intermittent potentiometer. Check to see if any of them are mechanically loose as this is a sign that they have been damaged and could have cracked the wiper surface inside the pot causing this problem. Alternatively, any switch that controls any gain setting could also be intermittent or dirty. Gain of the amplifier should be stable, but is controlled by the feedback and signal injection at the pots so that is where to look first. Good luck, as intermittent problems are tricky, but sometimes better than no function at all which can be more costly.
11/21/2017 6:23:21 AM • Marshall... • Answered on Nov 21, 2017
2answers
Electricity flowing. Why won't amp turn on?
What type of Marshall, please? First of all, control the fuse and let me know.
12/26/2015 6:04:44 PM • Marshall... • Answered on Dec 26, 2015
2answers
Marshall amp troubleshooting
Does anything happen while you turn the knobs on the amp? I had a similar problem with a yamaha amp. It turned out a couple of knobs went bad. Soldered new pots and it works fine for me now.
3/29/2015 11:37:19 PM • Marshall... • Answered on Mar 29, 2015
Can i connect 2 (2x12) cabs rated @ 4ohms each to my avt50 head?
No, the ATV50 head is rated for 4 ohms total. Using both 4 ohm cabinets at once will fry your amp. Your only option would be to rewire your cabs internally to 16 ohms each by connecting the speakers in parallel, but that would cut your amp's power in half.
1/25/2015 8:08:32 PM • Marshall... • Answered on Jan 25, 2015
1/25/2015 8:05:30 PM • Marshall... • Answered on Jan 25, 2015
0answers
Serial number, where is it located?
Some Marshall serial numbers might tell you the year your 3005 was made, Marshall stamped the different years of the micro's in different spots, your number could either be on the back metal plate stamped right above the AC power cable port, or barely visible on the front gold plate above the power switch just under the Tolex, at least that's where my 1988 3005's serial number is stamped. But it should have one on it somewhere, could even be inside the head too, my sis plays and has an old 1977 50watt tube head with an interior serial number. I've been a huge fan of the Micro stacks since they came out in the mid-80's. I believe the 3005's were only produced from 1985 or so till around 1988 or 89 in Black, White, Red, Orange, Blue, Purple, and Grey, a Camo Tolex was a custom option as far as I remember. 1987 was Marshall's Silver 25th Anniversary, so a Silver Tolex Jubilee edition was made that year only. Than the newer MG15-II's were made from around 2004 till 2010 along with the Zakk Wylde signature series micro stack,. And now they make the newer MGD's since 2010, I just tried one last week at my local guitar shop, I liked it a lot, it's very different sounding than my old 1988 or my 2009 micro's and has a few built in effects which weren't great, but not that bad at all, I have a 1988 3005 stack that came with Celestion G-10's in the cabs and an MG15-II series micro stacks, that one came with some no name 10's, but believe it or not they sound better than the G-10's! Mine are all in black, I have been after an original micro stack in white for many years.Did your old 1x10 cabs come with Celestions too?
4/24/2014 5:04:40 PM • Marshall... • Answered on Apr 24, 2014
Marshall Amplification Marshall Cover For Dsl401 Amp Logo
1 questions posted
Top Marshall Amplification Music Experts
matt martin
matt martin
Ngoro
ADMIN Eric
ADMIN Eric
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
View Most Popular
  • Marshall Amplification Music
Most Popular Question
after gig last night tried our marshall
  • Music
