20 Most Recent Rotel RX-965 Receiver Questions & Answers
2answers
My Rotel RSX-972 surround sound receiver has no
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
11/8/2016 7:20:39 PM • Rotel RX-965... • Answered on Nov 08, 2016
Hi i have a Rotel
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
12/14/2013 11:47:53 PM • Rotel RX-965... • Answered on Dec 14, 2013
0answers
E76-LE2-2/45 TK-1 transformer data sheet
Service manual says it has already selectable voltage transformer in it having selection of 120V, 220V and 240VAC. Anyway see page 9 of service manual ROTEL RX-855 Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
10/27/2023 1:25:19 PM • Rotel Audio... • Answered on Oct 27, 2023
2answers
ROTEL RCD-951 TM can not open tray.
Hello Ruben, so you do not open the CD holder tray of your Rotel, the problem is that the belt that transmits the rotation of the engine to the mechanism of the car, may be stretched and therefore the car does not open, this is the most common fault in this type of CD players You should replace it, if you can not do it, look for a specialized technical service I hope you can solve the problem Greetings Franco Dosil Hola Ruben, por lo que cuentas, no se abre la bandeja porta CD de tu Rotel, el problema es que la correa que trasmite el giro del motor al mecanismo del carro, puede estar estirada y por lo tanto el carro no se abre, esta es la falla mas habitual en este tipo de reproductores de CD Deber?s reemplazarla, si no puedes hacerlo, busca un servicio t?cnico especializado Espero puedas resolver el problema Saludos Franco Dosil https://elektrotanya.com/rotel_rcd-951-tm.pdf/download.html http://bwgroupsupport.com/downloads/manuals/rotel/RCD-951-OM.pdf
10/9/2021 5:20:27 PM • Rotel Audio... • Answered on Oct 09, 2021
I have an old surround sound reciver ROTEL RSX-1067 Mabee 20-30-40 years old : one day it just shuts down, just like that.
Several possibilities come to mind. First shorted connections to speaker wires. Faults in the power supply. Sometimes if the unit has not been working for a while the large capacitors in the power supply can dry up. An overload on a power transistors.
6/5/2021 2:58:48 PM • Rotel Audio... • Answered on Jun 05, 2021
I have a rotel rb970bx. I have 2 and ran them in
hi it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions uprate the fuses till they stop blowing
12/21/2017 9:15:36 PM • Rotel Audio... • Answered on Dec 21, 2017
Rotel rsx 1065 switches on. every single thing is lit up in the display panel on receiver. But unable to select anything and of course no sound. what could be wrong?
Probably the EEPROM, the heart and brain of the appliance. I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown. Not economical to repair.
11/20/2017 6:03:23 PM • Rotel Audio... • Answered on Nov 20, 2017
Rotel rcc-1055 won't stop spinning carousel. It will sometimes play a disc but mostly spinning looking for a disc
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
9/13/2017 1:38:23 AM • Rotel Audio... • Answered on Sep 13, 2017
0answers
Rotel RX-965 Receiver Logo
14 questions posted
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Larry
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Audio Players & Recorders
Most Popular Question
rotel rsx 972 surround sound receiver no
  • Audio Players & Recorders
