20 Most Recent Rotel RMB-1095 Power Amplifier Questions & Answers
hi
I can't give you the schematic diagram but I might help you. What is the problem?
Rotel RMB-1095... | Answered on Nov 28, 2013
Instead of replacing you can try and clean it. There are a lot of good contact cleaners out there.
Rotel RMB-1095... | Answered on Nov 17, 2011
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Rotel RMB-1095... | Answered on Apr 28, 2010
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Rotel RMB-1095... | Answered on Apr 10, 2010
All I can say to you is look around where the mains goes in very carefully. Fuses are sometimes hidden or in a case or cover of some kind. Sometimes amps use fuseable resistors. If the PC board is marked up look for resistors with "RF" or different indication to a normal resistor. Otherwise fuses will have "f" markings on the board. Remember the power supply part might be enclosed in a metal case with holes in it, so might be hard to spot fuses.
Rotel RMB-1095... | Answered on Nov 02, 2009
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
Rotel RMB-1095... | Answered on May 20, 2009
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
Rotel RMB-1095... | Answered on May 18, 2009
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Rotel RMB-1095... | Answered on Oct 10, 2008
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Rotel RMB-1095... | Answered on Apr 17, 2008
Try only A speakers.
Rotel RMB-1095... | Answered on Feb 12, 2008
if you say you checked the wireing ,did you check the speaker. disconnect on of the other speakers and connect up the center to see if you get sound. still no sound speakers bad. Got sound try unpluging unit for a couple of hours then try it again. still no center . Time for the repair shop. Good Luck
Rotel RMB-1095... | Answered on Nov 21, 2007
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Rotel RMB-1095... | Answered on Feb 26, 2007
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Rotel Audio... | Answered on Dec 21, 2017
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Rotel Audio... | Answered on Nov 20, 2017
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
Rotel Audio... | Answered on Sep 13, 2017
17 questions posted
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Audio Players & Recorders
Most Popular Question
problem ra 9808x
  • Audio Players & Recorders
