Posted on Mar 24, 2009
How do you make an audio cd from the voice files
I have made some voice files and want to put them onto an audio cd, yet when i go to make the cd the windows media player says, copy error due to the file being in a wav. format. How can you change the format of the files and make a cd??? Please help
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1827
Points
11
Open up the media player and try to drag the voice files to the media player and burn to your cd
1helpful
How do I make a audio CD from my dictation machine
If you are already using your dictation machine then you don't need to install its software as its already installed. Now you only require Nero for burning files to CDs. You also require a CD writer installed on your pc. You shall know where your files are saved when you record through dictation machine. If you can't find the recorded files kindly comment back.
Copy files to CD
if you know where the files are just put a blanck cd inth your disc drive oppen my computer and drag and drop the files into the icom for the blanck cd
then dubble click on the cd icon and on the left hand side of the window it should have an option "write files th cd" click on that and a wizard should oppen
its esay from then on
6helpful
2answers
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
2answers
When I burn a cd it is an application program not a audio cd.
In your application program is where the determination of audion verses application is made. Read you manual to determine how to select the proper settiings.
Can transfer but cannot burn
Not so much as a solution as a reason why it won't work. The Olympus web site FAQs says that you can't transfer onto an audio CD because the 4-bit depth used to expand the recorder memory can't be converted to a format that is compatible with audio CDs.
I'd be very pleased to find someone who's found a way round this as I brought this recorder to record my study notes, put them onto CD and play them to myself in the car, walking the dog, during lunchbreak etc.
Olympus VN-2100PC exported files
The only way I have found to convert the files is to use Nero or ITunes. Those are the only two methods I've found to read the file. ITunes can both burn them to an audio cd and convert the file to mp3.
Dowloading audio files onto my computer..
I have an Olympus recorder. I don't know if the software is similar but their software has a way of copying the files to folders in the software. These files can then be used in other audio programs such as ITunes if you want to transfer it to your Ipod or audio recording software so that you can drag and drop them into one file.
If you look in the folder where your voice manage software is, is there a folder where the audio files are being stored within the program?
2answers
Formatting a file to an audio cd
write an 'audio cd' by the roxio creator, instead of directly buring the file to CD
Please choose an option to write 'audio CD' bcos most of the CD players do not recognise other formats
u may use some free audio CD creation softwares also... If i am right, winamp may also help
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
 Grubhead
Grubhead
SmartAviator
SmartAviator
