Sub-Zero 690 Side by Side Refrigerator Logo
Posted on Mar 24, 2009
Specific dimensions of a side by side model 532
I need to replace my 532 and need to know the exact dimensions of the unit so it will fit into the cabinet space he old one occupied.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2279
Points
6
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
What new Pioneer radio with back up component would replace my old unit
It sounds like your question should be either, "What Pioneer unit is compatible with my installation (Car make/model)?", or the question should be "which new Pioneer model would be comparable to the level of quality of my original unit?" Both questions have a similar answer.
Pioneer has a full range of quality levels for their products including the Pioneer "Premiere" line, on down to the basic models that have very few extra features. For either question the answer would be to match the Pioneer model with all the same exact features as the original unit, and that has similar performance specifications. This will provide the quality that you are accustomed to. If an earlier model of the same quality level classification fit in the particular car you are driving, then its predecessor model will probably have very similar physical dimensions and should fit nicely too.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_4c629b5aef073a57
Can I replace the 215/70/r15 tires on my 2003 Kia Sedona with 235/75/r15 without an issue? I dont want it to rub anywhere as it is a bigger tire.
there are two differences in the tires
one is bigger in the side wall height and holds the rim edge further from the road
the other is the fitted rim width
that is the problem dimension because if it is wider that the rim dimension it will allow the tire to roll off the rim when cornering
It may also cause problems with rubbing as the side wall are greater than the other size
For legal and exacting information of substituting tires , talk with a tire retailer as they have the experience to know exactly what you have
Charmglow 810-6805-0 is the grill we have! It's a built in and we need to replace the entire grill? How do I find that grill so it fits the dimensions of what we have? Thanks
You won't find that grill anymore. Models come and go like waves in the ocean. You may find one with the same dimensions, but you won't find a new replacement for that exact model. This is the pitfall of "built-in" grills, as they have a tendency to need replacement within 5-7 years on average, due to wear and tear, and the elements. All a "built-in" grill is, for the most part, a typical grill that has not been mounted on the base unit and instead mounted into some kind of enclosure.
Sep 25, 2016 • Grilling
I need the dimensions of Amana side by side fridge freezer. Model no. sBDE520SW
U contact the manufacturer of the remote for the codes, if any.
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
2answers
I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
I have this exact model. Here are the specs:
depth: 30"
height: 68.5". with hinge: 69.5"
width: 35.5"
15.5 cubic feet in the refrigerator section
10.0 cubic feet in the freezer section
25.5 cu ft total
Find a replacement for Kitchenaid KEMS376S ~ tricky dimensions
your local dealer shouold have available to them all the manufacture specs and which unit would fit your needs.
1helpful
2answers
What battery part do i get for my 883 sporty XL 2004 model
If you want an original battery by Harley the Part nº is 65958-04.
This is the link for that specific battery for the 2004 model:
http://www.batteryweb.com/motorcycle-batteries-detail.cfm?model=65958%2D04
If you like other options from other brands, please visit:
http://www.batteryweb.com/motorcycle-batteries-list.cfm?ID=697&motorbrand=Harley%2DDavidson&cc=883
Hope that helps.
Unsure if my wireless PCI adapter will fit in my dimension 2400?
You can get your systems exact specs on the Dell website under the support page. Hope this helps.
Top Sub-Zero Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
