I have not seen a RT707 but in the RT909 there are reel settings for the reel motors as far as torque goes. A copy of the service manual will tell you how to set these tensions. I suspect that you have a setting that favors one direction.
Someone will have to open the unit to see what is happening---either tape is not loading all the way or when FF or Rewind hit not moving the reels----could be as simple as a belt or a bad drive idler (most use either a rubber wheel or gears to move the tape in Play, FF, and Rewind.
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
Make sure there is no disc in the player.
Turn on the player (you can use remote control or front panel, it doesn't matter)
Wait for "No Disc" message to appear on the TV screen.
Press the Repeat button on remote (plain, not A-B).
Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
Region 2 players: FF, FR, FF, UP, DOWN
Region 3 players: FF, PLAY, FR, UP, LEFT
Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
Region 5 players: FF, UP, DOWN, STOP, RIGHT
Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Press and hold the [D] button for 1 second or longer to switch to the adjustment selection display. Press <<(rewind) or >>(fast forward) to select CLOCK. Press Play/Pause button. Press <<(rewind) or >>(FF) to select the hour or the minute. Turn the [Rotary] knob to set the correct time. Press the Play/Pause button to store the time into memory. Press the [D] button to return to the previous mode. Reference page 9 in this link to your Clarion DB165. http://www.clarion.com/us/en/MungoBlobs/615/345/DB165-ENG.pdf
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
