MAG M24LM 24" LED Monitor Logo
Anonymous Posted on Jun 07, 2013
Stuck on 640 resolution
For some reason, after moving, I setup my my desktop with monitor. When I plugged in monitor it went to the 640 resolution and I can't change it on the screen resolution menu (no other options are available) I tried reinstalling my AMD catalyst to update driver and seeing if the monitor had a missing driver but it still wont change. Also for some reason its labeled as a "Generic non-PnP monitor"
RAGHU
Level 3:
Master:
Sergeant:
  • Master 401 Answers
  • Posted on Jun 12, 2013
RAGHU
Master
Level 3:
Master:
Sergeant:
Answers
401
Questions
0
Helped
75805
Points
1104
INSTALL CORRECT GRAPHICS DRIVER
Testimonial: "if you read my description, i already did that. i even uninstalled my graphics driver and reinstalled"
I had problems with my monitor. I am purchasing a new monitor. When the new monitor is connected to the computer does the BIOS default setting adjust to the new monitor? I am just a computer user not,...
Sometimes the BIOS doesn't display properly on the widescreen monitors if your video card was built before widescreen monitors were acceptable. I have an old ATI Radeon video card from 2006 and it cuts off the BIOS setup screen when setup. If a 640 X 480 monitor was plugged it, the problem would go away. The graphic drivers aren't going to initialize in your computer until the computer is booted which compensate for the current resolution settings.
Another solution is to see if you have a BIOS upgrade available for your computer that will create a resolution and refresh rate that will work for your monitor.
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
I have been having trouble with the screen image moving to the right so that there is about a 2" bar of black in the left margin of the screen. I went to my control panel and adjusted the screen resolution...
you need to reboot into safe mode (hit F8 during boot up), then set the video to 640 x 480, then reboot into regular mode , then reset it again to the native resolution of this monitor, 1440 x 900 @60 Hz.
The monitor this old may also have capacitors problem, http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Post post back so it may also other people also..
My screen resolution is stuck at 640 X 480 and it can't be moved in the display area. Any suggestions?
The resolution of teh screen is controlled by the computer, not the monitor.
Find your display settings in whatever operating system you are using. You will be able to change the resolution there. Easiest way would be to do a Google search for "change resolution in XXXXX" where XXXXX is your operating system. (i.e., Windows XP, Windows 7, Mandrake, etc.)
I have a hp desktop model a1268c computer. after an update my computer srcreen says ''input not supported'' and the screen is blank. When the computer boots the F1 button ''setup'' works but the F10 button...
> You needs to configure your scree resolutions and other parameters.
> May be frequency rate doesn't supported by your old Monitor.
> Just attach your desktop with different monitor and change parameter to lowest frequency range. (60 HZ or lowest with 640*480 resolution)
Resolution problem in Cricket 07
you need to check if your computer monitor supports resolution above 640 X 800 pixels or not, if you have a windows operating system you can check this by right clicking on your desktop ->Properties -> Settings -> Screen Resolution, check here by moving the slider bar what is the maximum video resolution supported by your PC
Also check if your computer meets the minimum requirements required to play EA Cricket 07
Screen Resolution stuck at 640 by 480
you first install the audio drivers if the problem persists then attach AGP card then increase resolution and pc will ask question do you want to keep these settings say yes then you can see 1280x1024
Can't change resolution on older monitor M50
It seams your video card is not properly install. If you have more option greater then 640*800 then it means your monitor not support above resolution that you mention.
If problem is not this which I mention then please reply to this thread with explanation.
Top MAG Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MAG Computer and Internet Expert? Answer questions, earn points and help others
