Air Tools & Compressors Logo
Posted on Mar 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air compressor fills, but slows down as the pressure builds
After i changed starting capacitor air compressor begins to fill runs good for couple of times.and now air starting fills with air, but slows down as the pressure builds up in the tank about 60psi. It is an oil lubricated twin cylinder. The motor is a Doerr Emerson Electric 15 amp. I tried replaced running capacitor but same result.
what is problem?
  • Anonymous Mar 23, 2014
    Compressor lubricant
Joe Garcia
Level 2:
Champion:
  • Expert 210 Answers
  • Posted on Mar 23, 2009
Joe Garcia
Expert
Level 2:
Champion:
Answers
210
Questions
0
Helped
76310
Points
392
Sounds like you need a new check valve which should be somewhere between the compressor outlet piping,tubing,etc and the tank which prevents the air in tank to back feed to the compressor which would cause hard starting and could damage the motor easy way to check is when you shut off the compressor with some air in the tank if the check valve is bad it would continue to bleed air out out the unloader valve .the unloader valve on your unit is most likely part of the pressure switch when the unit shuts of it should only bleed down the pressure in the pump so it would make it easy to start when needed hope i didn't confuse you
  • rezero101 Nov 03, 2010
    I bought the 60 gallon compressor brand new at Lowes. 2 months in the set screw for the big pulley fell out and started rattleing around. 6 months in the belt started to burn and stink. 6 months after that the compressor slows down tremendously at 60 psi and takes forever to build up enough pressure that by the way is now around 142psi opposed to 135psi which is where it use to stop. in the last several days i have changed both capacitors and the check vavle. had a certified person come and take a look and he says the cylinders look brand new and all gaskets are great. his only advice is a new motor. The motor is only a year old. obviously i am not happy with Campbell Hausfield and would never reccomend it to anyone unless i can get some excellent customer support
  • markusunread Dec 04, 2010
    The check-valve tip is great - but there is another failure that can cause the same symptoms. If your compressor motor has a "run capacitor" along with it's "start capacitor", it can be a bad "run capacitor. I have a compressor like that, with two "lumps" on the motor. One is the start capacitor and the other the run capacitor. The run capacitor failed shorted and the motor would struggle for a few seconds until it popped the breaker. To check the capacitors, disconnect them from the motor, short the terminals and use an ohm-meter to check for a short. If the resistance starts low and goes up, the capacitor is good. If the resistance stays the same and low (less than 100 ohms) it's shorted. If the capacitor, after shorting the terminals, immediately shows a very high resistance ( greater than 1 megohm) then it has probably failed "open".
    I found an unexpected source for motor run capacitors - pool/spa parts suppliers!
1helpful
Hi there, I have a Makita 5200 compressor. When the air pressure starts to build, oil is blown out of the crankcase breather. I add oil and right away it blows that out too.
Piston Rings or Seals have failed.
Why does oil come out of the oil fill tube? ' About Air ...
https://www.about-air-compressors.com > why-does-oil...
It won't build up any more than 40 psi. ... I have oil blowing out of the oil breather on the pump. ... worn, and you are getting oil blowby into the air pressure chamber as the compressor runs. ... Doug in s.d.ca on Identifying An Older Air Compressor; Doug in s.d.ca on Craftsman upright air compressor slow starting and blowing ..
Apr 13, 2021 • Motorcycles
1helpful
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
1helpful
2answers
How can i fix my ec12 hitachi electric air compressor
This problem is caused by either the starter capacitor or the in-tank check valve. Ez to check. With no air in tank, start compressor; if motor hums or has difficulty suspect capacitor. If motor starts, partially fill tank and unplug the power. Check for air leaking at the pressure switch or air coming out of the air inlet (remove the air filter). If air leaking, replace check valve. If no air leaking, again let out all the from the tank and connect power. Allow the compressor to fill and shut-off. After the compressor fills, again listen for air leaking from the pressure switch unloader valve. If air continues to leak from unloader, replace the check valve. Good luck
I have a tractor pto driven air compressor and when it gets close to the cut off pressure of 120 psi the cylinder stroke slows way down and over a period of time running it, it will push oil out the oil...
The rings are the most likely by your description. As the air pressure builds up more air goes past the rings and pressurizes the crankcase and probably causing the oil to foam. Rust pits and cylinder scoring exacerbates the problem.
First try changing the oil and make sure the crankcase breather is open and baffles clean. Make sure you use compressor oil that is formulated to minimize foaming.
Second, try adjusting the unloader to a lower pressure. 120 PSI is nearing the upper limits of efficiency and sealing for a single stage industrial compressor. Something like 110 PSI may do the trick.
Third solution is to rebuild it, but it may last for many years at a slightly lower pressure.
EC89 HARD TRIPS RESET ON COLD STARTS.SOMETIMES WONT FILL AT ALL.WHEN IT DOES WILL NOT FILL PAST 50PSI
Several things to check. Check amp draw with meter to make sure that the reset is not bad. It amp meter is showing low amp draw when it trips, then replace reset. If reset is good check condition of the cold start valve. The valve will not allow pressure to build until motor is at full rpm and the pump is making good pressure/volume. If cold start valve does not close, check pump for leaking or broken reed valves. If cold start valve is good, check the capacitor for at least 10 percent of rated valve. Low pressure /volume is usually leaks from tubing or leaking /broken reed valves or burned gaskets in the head of the pump. Finally, make sure that the check valve or non-return valve is not leaking pressure from the tank causing back pressure. Good luck
2answers
All Trade 5 Gal just humms wont turn on
The start capacitor has gone bad. Needs to be replaced. That's what's inside that bump on the side of the motor.
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
I have an upright craftsman compressor which is VERY slow at building pressure. The shut off is 150psi. When I use the unit, and it turns on, it runs forever to build back up, even when im not using it....
Your unit should fill within 5 min. Compressor may have worn cylinder (assuming oil-less) , worn valves or just leaking. Easy test. Spray soapy water on all connections/fittings including drain valve and regulator while compressor is running. Repair as needed. If no leaks, remove plug from outlet, remove cover and examine cylinder. Turn crank by hand till piston is all the way up into cylinder. Examine carefully the condition of the cylinder close to top. If the cylinder is scratched or worn then pressure is leaking between piston/cylinder and will not fill tank properly. Replacement cylinder kit available at Sears, cost under $50. If no leaks and the cylinder looks good, then valve plate may have broken gasket or reed valves. Replace as needed. Good luck with your project.
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
3helpful
Starter valve dont close hatachi ec119sa (air compressor)
The start valve gives your motor a running start before the motor begins to load as the pressure increases from an empty tank. The motor strain is more profound when there is pressure in the tank. If you plug the valve, the motor will instantly encounter a heavy load because it has to force air into a partially filled tank. This extra load without the valve will shorten the life of the capacitors and motor windings. There could be two problems with your unit that can revealed by test. What actually closes the valve is a certain volume of air produced by the compressor. If the compressor is not pumping to full efficiency or there are leaks in the discharge hose the valve will not close. Or the valve is faulty. With an empty tank, plug the valve and run compressor and test airline for leaks with soapy water. If no leaks, empty tank of air and restart compressor and take note of the amount of time it takes to fill the tanks to shut off. If it takes an unusually long time to fill, then the compressor probably has valve problems causing low air volume. If the compressor fills to shut off in a short time frame as compared to a similar model then replace the valve. Leaking valves in the head will also cause the pump and discharge tube to run very hot. Parts are available at www.toolpartsdirect.com Good luck with your repair.
Top Campbell Hausfeld Air Tools & Compressors Experts
john h
ZJ Limited
ZJ Limited
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
