SOURCE: GE GSS20IE Ice Maker
Even though the fridge was given to you it still has a 1 yr warranty from manufacture date. Look on the sticker inside the fridge and see if it gives the manufacture date or get the receipt from you gave it to you. Call 1-800-905-9505 for service. They are nationwide (US). If you find out it is older than 1 yr then use the model # on that sticker and go to www3.sears.com to get the correct part # for the icemaker. Unfortunately these come as a whole unit and can't replace parts. Once you have the correct part # I bet will find a good price on ebay for a new ice maker. If you need help finding the part # or any other questions let me know. If you feel I didn't help solve your problem please let me know before you rate this solution.
SOURCE: ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
SOURCE: GE Model GSH22KGRBWW has two problems. 1st
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
I have had some of these same units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution for the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
SOURCE: GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
