Do not see my original post up here...sorry if there is duplication.I'm trying to install a sound bar to my PN51D550 and there are only Audio In plugs..no Audio OutSoundbar isnt working think this is the issue... would appreciate any insight/assistance (( tv not on Game Mode & no firmware updates listed on Samsung website...
Looks like you will need an optional cable - a Digital Audio Out Optical cable. You can buy one at Radio Shack, Best Buy, most department stores that sell TVs.. Ref to pg 12 of the user manual..
https://www.manualslib.com/manual/760128/Samsung-Pn51d550.html?page=12#manual
SOURCE: Samsung LN-T3253H LCD Sound Problems
PEOPLE, YOU NEED TO GO BACK TO THE STORE, BUY THE SAME TV AGAIN, SWAP THE TV'S AT HOME AND RETURN THE "OLD" TV IN THE "NEW" BOX WITH THE NEW RECEIPT. IN THE CASE OF TOO MANY RETURNS, HAVE A FRIEND, MOM, DAD, SISTER, GIRLFRIEND TO BUY ONE FOR YOU AND DO THE SWAP LATER.
NOTE: I REALLY HATE DOING THIS TO THE STORES, BUT IF YOU PAY FOR SOMETHING IT SHOULD LAST LONGER THAN 30-40 DAYS. PROBLEM SOLVED! :)
SOURCE: I have updated the Samsung LN32B360's firmware
Reset the Audio setting back to factory setting.Unplug,replug it a couple mins.will get ur sound back,If u up date the correct firmware.
SOURCE: Can somebody pls. help...our tv Samsung LN40A550
This is a very common problem. The power supply board has failed and needs to be replaced. You can call 1-800-samsung to find out if this problem will be covered under a warranty and the nearest service center. I replaced at least 150 power supplies last year.
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
