Feb. 29, 2016 - Memory loss occurs if the the scanner is left for a long period of time without power. Please note that in case of memory loss to the scanner ...
memory loss. If memory is lost, simply reprogram each channel. The display shows "MEMO LOSS" when memory is lost. Always press each keypad button firmly ...
A> Check you Power all connection proper connected. B> Check you SMPS power proper working or not. C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem. D> Check you RAM, section if RAM problem then display no. E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut. Thanks...
MAYBE THERES AN ALARM SYSTEM DRAINING BATTERY BEST WAY TO CHECK IS REMOVE BATTERY LEAD ,AND WTH EVERYTHING TURNED OFF SHOULD BE NO SPARK WHEN YOU RECONNECT
Reason for your battery being drained is becuz your alternator isn't able to keep up with the power distributed to your amps becuz you are pushing way too much power. I would recommend a bigger alternator, separate batter for your cap and amps so your battery isn't drained.... Yes I understand that the cap is suppose to hold the power but your electrical system wasn't designed to take such a power loss due to running your stereo.
If it"s an aftermarket radio, orange wires often aren't used, (it's usually for dimming) try it without connecting the orange wire, but be sure not to leave the wire exposed.
Without hearing it, it is hard to tell. But, I would first be looking at the idler pulley bearing, they have been known to fail; and make noise. Remove the idler pulley, and spin it manually. If it feels rough, and makes any noise, it is bad.
Hello, You may be right. I have left batteries in my TI92 for years without using it. When I put in fresh batteries, it came back to life. The backup battery of my TI92 (bought a dozain years ago) has not been changed yet.
There is a small bypass hose for the thermostat. Are you asking how to do a complete flush? If you want to make sure you get all the coolant out there is a 14mm drain plug on the left side of the engine block that will allow all the coolant to drain. It is tough to get to without the right tools. Make sure you remove the small bleeder screw on the thermostat housing when refilling so all the air is purged from the system.
