Mitsubishi WD-73833 73" HDTV Logo
Anonymous Posted on May 21, 2013
TV CHANGES BETWEEN FORMATS, INTERMITTENTLY - Mitsubishi WD-73833 73" HDTV
I changed the video format on my night owl DVR and now I cannot get it to display on my tv. An error message appeared on the tv stating "resolution mismatch! change devices resolution"
hi,
maybe when you changed the video format the resolution of the screen was changed or
the new format needs another resolution.
try to change the resolution of the screen
daniel
https://www.rylwy.com/
How to fix my Samsung tv ..picture goes in and out intermittently
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
How do i change my fornat/resolution on my model wd-82738 tv
See page 6 (this is a display & basic explanation of your transmitter) of the owners manual http://mitsubishi-tv.com/asset/file/basic_owners_guide/738-838_BIB_v3.pdf
there is a format button on you remote transmitter. If you have other format issues it is probably your source & not the TV. You may have to change the source format in which case you will need that mfr. operating manual.
The heads are cut off....I only have my dish remote, Is there a way to fix the format from that tv or a button on the tv itself it is a 52" or 60"
How did this start? you need the remote to change the settings in the first place, somebody used it to change the settings! Have you tried using the dish remote, did you change the format on dish? there is a place on the remote that changes the format from the sat signal also, should be a yellow bar below the live TV button. This is the way mine is set up but on other remotes there is still a button to change the format, look on the dish remote for this.
Word Component1 shows up when changing local channels
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
2answers
Intermittent sound distortion
download kazza lite codecs for your videos and update your sound drivers from windows update.
Hello my sonyericsson p1i dosent read my stick memory and says it's corrupted I restart it and tried to change the memry but doesn't work please of u can help me ... and thanks for every thing
I had the same issue. Mine was intermittant. Sometime the card was recognised, sometimes not. Formatting the stick was the only cure. Quad sphere icon -> Contral panel -> Other -> Format memory stick.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
