20 Most Recent Mitsubishi WD-73833 73" HDTV Questions & Answers
The part to fix that is about 300 dollars.
Mitsubishi... | Answered on Jan 26, 2018
Howdy Mike-d. here,
I do not know what a DMD is on a Mitsubishi 73'' TV.
I did do a little web searching and here is a couple of things I came across.
From this website: http://www.tvserviceparts.com/Mitsubishi_DMDChips.html WD73833 ALL 4719-001997 DMD Chip, DLP, 1920X1080/XHD5, 0.65"/ DC4, TYPE X NON
I have no ties to these websites.
"I researched this and it was a DMD chip that needed to be replaced."
from this website: http://www.consumeraffairs.com/home_electronics/mitsubishi.html
Hope that helps.
Mike-d. out
mikedee4@gmail.com
Mitsubishi TVs and Electronics Mitsubishi TV DMD DLP Chip
Mitsubishi... | Answered on Jul 01, 2014
Usually lamp getting bad.
Mitsubishi... | Answered on May 16, 2014
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Mitsubishi... | Answered on Dec 24, 2013
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Mitsubishi... | Answered on Sep 14, 2013
need to replace the dlp chip under 200.00
Mitsubishi... | Answered on Aug 28, 2013
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mitsubishi... | Answered on Apr 25, 2013
It is the Optical lamp board
Mitsubishi... | Answered on Feb 23, 2013
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Mitsubishi WD-73833 73" HDTV Logo
54 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
turn mitsubishi wd 73833 tv turns itself
  • Televison & Video
