Sanyo Xacti VCP-HD2 Camcorder Logo
Posted on Mar 17, 2009
Lcd on Video camera not working
Went to turn on video camera (Sanyo Xacti 5.1 MP) this weekend and something has happened to the LCD Screen. It will turn on but it looks like it been cracked. Need to replace. not sure who can replace it?
  • 1 more comment
  • Anonymous Mar 17, 2009
    I've tried to take the LCD screen apart but I can't get it to come off any suggestions.
  • Anonymous May 17, 2009
    The problem is not the lcd, its a conncetion in the body from the lens to the recorder, and you have to have it reprogramed. Can't find a repair in San Diego..Help
  • Anonymous Feb 11, 2013
    hay where did you get that lcd because i am also looking for lcd Sanyo Xacti VPC HD1000
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
386
Points
Take the LCD apart & look up the numbers on the back of it, order the part from were ever you find it form google & put the new one in urself when it arives, this will safe you @ least 100$ on someone else doing the same thing
I need Sanyo Xacti VPC HD1000 LCD
http://www.fixya.com/support/t1813324-lcd_video_camera_not_working
Apparently you can take the LCD apart, look at the part number and order it online somewhere.
Try shopwiki.com
Hello I have got camera Sanyo Xacti vpc - ca9gx. Recently i lost mic but camera still was recording but after while stop working. On the top is red light flashing but it is not starting. I have open the...
Think you have it about thin sheets like fcc flatcontactcable that can about problems with sun heat build up inside there are special hotmelt repairs something like this kind of fcc without tools very difficult . hope you can something do with it knowing that Sanyo was become a part of PANASONIC in 2008
How to repair Flex cable Flexible PCB type flat copper ribbon cable Sanyo VPC CA9 Xacti Camcorder 720p Quick Manual
2helpful
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Black screen when camera is turned on
Sanyo will replace it for $50 if you mail it to them. Just contact them for the address and slip.
This is common. The parts are hard to find. Your best bet would be ebay
COPY AND PASTE THIS LINK IN YOUR ADDRESS BAR;
cgi.ebay.com/SANYO-XACTI-VPC-E6-LCD-SCREEN-DISPLAY-REPLACEMENT
1helpful
2answers
SPLIT SCREEN PROBLEM
You can buy a new LCD and flex cable for $78 at the place Sanyo recomended to me. It takes a week for them to order it and a week to ship out. Call 1-800-421-5080 and give them part # 6450930331.
Mine has the same problem. I took it apart and by pressing on the flex cable my picture was restored. As soon as I let go the screen would go. Trying to decide between replacing the part or the camera.
LCD SCREEN
Cracked your LCD screen, the black lines are where it broke.
2answers
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
3answers
My Sanyo Screen is broken
After some work I think I have an idea how to repair a broken lcd screen on your Sanyo 6MP Xacti Digital Camera. Perhaps this will also work on other cameras.
1. Unscrew the 6 screws around the camera. Facing the lens you will find 2 screws on right side, 3 screws in the bottom and 1 screw on left side - there is also 1 screw under left side panel that you can unscrew after carefaully lifting of the panel.
2. Remove front panel.
3. Look at attached photo and unscrew the 2 screws that hold the back cover (it took me some time to find them I can tell). Perhaps you need to remove some screws that holds the curcuit board.
4. Remove the wiring shown on the photo that holds the lcd screen.
5. Remove the back panel and unscrew the 3 screws that holds the small lcd screen small curcuit board.
For the moment I don't know there to buy a new lcd screen but I guess it will be possible to find at a repair shop on Internet. For other marks I have found lcd screens for about $60.
Top Sanyo Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
