20 Most Recent Sanyo Xacti E6 Digital Camera Questions & Answers
8answers
Sanyo xacti e6
TRY TO DO THIS FEW STEPS & INSTRUCTION;
  1. If your camera is still under warranty, the best thing you can do is to take it to the nearest official repair shop and they should fix it for free.
  2. If your camera is out of warranty, or if the manufacturer refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try the following methods to repair it yourself.
  3. First, make sure your camera has fresh batteries and it is in recording mode.
  4. Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
  5. Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
  6. Another method is to tap the padded USB cover part on a hard surface, for example, a desk. Sounds simple, but it works.
  7. Try forcing the camera lens. Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended. Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
  8. If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
  9. Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
12/5/2016 5:49:11 AM • Sanyo Xacti E6... • Answered on Dec 05, 2016
I want to connect my
The best, simplest and fastest way is to use a memory card reader.
Later if you wish to format the memory card, do it in the camera, but never in the computer.
6/30/2011 9:46:11 PM • Sanyo Xacti E6... • Answered on Jun 30, 2011
2answers
Dear Sirs, my sanyo camera is
If the "pink traces" appears in the LCD, isnt a malfunction, is a condition due to crystal liquid.
If this condition appears, necesarilly visit your photostore.
5/12/2011 8:10:37 PM • Sanyo Xacti E6... • Answered on May 12, 2011
My Xacti SAnyo Camera, it will not on by switching
Have you checked its batteries? Replace the batteries and turn it on again.
2/25/2011 11:44:21 AM • Sanyo Xacti E6... • Answered on Feb 25, 2011
Is SDHC cards with 4
Sorry, your camera is not compatible with SDHC. My best advice to you is to find a 2Gb card and be certain it does not say SDHC on it.
2/5/2011 5:53:27 AM • Sanyo Xacti E6... • Answered on Feb 05, 2011
How can i reproduce the videos i have on the
hook up the usb an open the file click on the video an itshold come up
4/17/2010 1:19:53 AM • Sanyo Xacti E6... • Answered on Apr 17, 2010
Hi, when i switch my camera on the front does not
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
12/7/2009 10:51:47 PM • Sanyo Xacti E6... • Answered on Dec 07, 2009
Black screen when camera is turned on
Sanyo will replace it for $50 if you mail it to them. Just contact them for the address and slip.
This is common. The parts are hard to find. Your best bet would be ebay
COPY AND PASTE THIS LINK IN YOUR ADDRESS BAR;
cgi.ebay.com/SANYO-XACTI-VPC-E6-LCD-SCREEN-DISPLAY-REPLACEMENT
9/18/2009 8:21:36 PM • Sanyo Xacti E6... • Answered on Sep 18, 2009
Camera got run over-where can I send it to get it fixed?
I would call your local camera shop to see if they can give you a quote over the phone to fix.
1/23/2009 2:37:25 PM • Sanyo Xacti E6... • Answered on Jan 23, 2009
Wont power on
Check the following URL for help:  http://sanyoservice.com/pdf/images/VPCE6(OM)2.pdf
11/27/2008 12:52:14 PM • Sanyo Xacti E6... • Answered on Nov 27, 2008
3answers
My Sanyo Screen is broken
After some work I think I have an idea how to repair a broken lcd screen on your Sanyo 6MP Xacti Digital Camera. Perhaps this will also work on other cameras.
1. Unscrew the 6 screws around the camera. Facing the lens you will find 2 screws on right side, 3 screws in the bottom and 1 screw on left side - there is also 1 screw under left side panel that you can unscrew after carefaully lifting of the panel.
2. Remove front panel.
3. Look at attached photo and unscrew the 2 screws that hold the back cover (it took me some time to find them I can tell). Perhaps you need to remove some screws that holds the curcuit board.
4. Remove the wiring shown on the photo that holds the lcd screen.
5. Remove the back panel and unscrew the 3 screws that holds the small lcd screen small curcuit board.
For the moment I don't know there to buy a new lcd screen but I guess it will be possible to find at a repair shop on Internet. For other marks I have found lcd screens for about $60.
11/16/2008 5:23:09 PM • Sanyo Xacti E6... • Answered on Nov 16, 2008
Black screen
It sounds like the shutter mechanism in your lens has stuck closed. This mechanism blocks out the light when you push the button to take a picture, allowing the image sensor to record what it saw just at that moment. If the shutter sticks closed then the image is always dark. You can see the shutter when it is closed from the outside, this is probably what you see when looking into your lens. Fixing this problem generally requires complete disassembly of the camera body and lens to reset the malfunctioning elements. Check with your manufacturer for recalls or technical bulletins, and see if they will fix it under your warranty. If this does not work out you can find good service providers online who can work on your camera. David Millier Advance Camera Repair
10/18/2008 11:58:14 PM • Sanyo Xacti E6... • Answered on Oct 18, 2008
Black scrren
Check out the following URL for help:  http://sanyoservice.com/pdf/images/VPCE6(OM)2.pdf
10/18/2008 2:05:54 PM • Sanyo Xacti E6... • Answered on Oct 18, 2008
Sanyo VPC-E6
Ensure that the video format you are using is compatible.
8/1/2008 6:38:28 PM • Sanyo Xacti E6... • Answered on Aug 01, 2008
Hi There, I have a
Hey sue9268,
I would first try cleaning the battery contacts. If this doesn't work then this problem is most likely caused by either a faulty battery pack or battery charger. Most retailers that sell cameras should have a charger that you can test your battery pack on, and if the battery pack tests out fine then you should probably purchase a new charger. Of course if the battery pack is bad then you should purchase a new battery Pack. If none of this works I would have your camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
7/24/2008 2:56:33 PM • Sanyo Xacti E6... • Answered on Jul 24, 2008
Sanyo Xacti
Either the CCD imager is failing or there are ribbon cables that are coming unseated inside. IF it's cables it should be a cheap fix. If it's the CCD it will be upwards of $100.
9/22/2007 5:44:32 AM • Sanyo Xacti E6... • Answered on Sep 22, 2007
2answers
Why won't Sanyo Xacti camera does not power on after being charged?
not car moved this to camera no model told at all the batteries are no good or connections rusty on most many of these are 13 years old and sold as new by liars endless on the web . models vcp-nnn (lots ) DMX-nnn (lots) the endless list is here. what it uses inside who knows lacking model the battery is bad, or allowed to leak and damaged connectors.
3/3/2023 6:24:09 AM • Sanyo Xacti... • Answered on Mar 03, 2023
0answers
Sanyo Xacti E6 Digital Camera Logo
Popular Tags
21 questions posted
Top Sanyo Cameras Experts
NOEL
NOEL
Ngoro
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
View Most Popular
Xacti Sanyo
  • Xacti Sanyo
Most Popular Question
sdhc cards 4
  • Cameras
