Polycom Vs4000 Video Conferencing System Vs-4000 Logo
Anonymous Posted on May 11, 2013
What model Sony camera
The two sony cameras for the system were stolen and need to be replaced. Not sure what model was there originally.
How do i check a serial number
Unfortunately there is no central database or system for this sort of thing.
It is possible (but extremely unlikely) that you could contact Sony customer support and tell them your concerns and supply the serial number. If the original owner registered their device it is remotely possible that Sony could contact them and inquire if the device was sold, stolen or reported missing. However not everyone registers their devices and if it was never registered this wouldn't work.
This is an extreme longshot, however, unless you are talking about a professional studio camera worth tens of thousands of dollars. It is highly doubtful that Sony would want to get involved in tracking down the legitimate owner of a standard consumer device.
Another option is to call the police department (probably where the seller is located) and inquire if that device with that serial number has been reported as stolen.
If you are buying a used item and have even the slightest doubt about it being stolen the best advice is do not buy it. Buying a stolen device is an arrestable offense (Receiving Stolen Property) and, although unlikely, you could get in trouble for it if there was an investigation or the seller got arrested subsequently.
A price that is "too good to be true" is a bad sign. Trust your gut and, even though it might be something you really want, avoid it if it seems questionable.
I upgraded my notebook from windows xp to windows7 and since then the webcam hasnt been working
Hello Poseout2002,
This is probably is simple problem with missing drivers. Since Windows 7 is backwards compatible with most of the hardware and software used with Windows XP you simply need to go to the Sony website and download the respective driver for your camera. Click here to be redirected to the Sony Drivers and Support website.
Make sure the Operating System selected is Windows XP and download both the camera driver and the utility.
Specific name of both files are "Original - Sony® Visual Communication Camera VGP-VCC2 Driver"
and "Original - Sony® Visual Communication Camera Driver Utility for the PCGA-UV10, PCGAUV11, and PCGA-UV11A"
Install both and restart your pc.
Everything should be in working order from then on.
-bsalamakha
How to replace the display of a sony DSC-W55 camera
It's easy - take it apart carefully and hopefully you have the replacement display, then make sure you connect the ribbon cable exactly like the old one to the main board. Then carefully reassemble. Make sure you put the screws back in to there original areas.
1helpful
2answers
When I turn it on the screen stays black until I
  1. Ensure the camera is turned on.
  2. If applicable, ensure the lens cover has been removed before taking pictures.
  3. Ensure the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. NOTE: Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon [FIG. 1]. This button could be a standalone button or incorporated as one of the control arrow buttons depending on the model of camera.
  4. If operating the camera with a battery, ensure the battery is fully charged.
  5. Ensure the battery is inserted properly in the camera.
  6. If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
  7. Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
  8. Perform a reset procedure on the camera.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony Service Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Try to reset the camera to original settings:
How to reset a Cyber-shot® digital still camera back to original factory settings. Solution
sp.gif sp.gif Cyber-shot cameras nowadays have a built-in rechargeable battery for retaining time, date, and other settings. Since the built-in rechargeable battery is not removable, current Cyber-shot camera models can only be returned to the original factory settings by pressing a small RESET button on the camera or by using an Initialize option in the menu.
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESET button or Initialize option in the menu. These cameras require a manual power reset.
IMPORTANT: To determine whether or not your camera has a RESET button or Initialize option, or for other model-specific information to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Date and time mode
Older-model Cyber-shot cameras (prior to the year 2000) do not have a built-in rechargeable battery and do not have a RESETbutton or Initialize option in the menu. These cameras require a manual power reset.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Sony dcr-dvd201 camera stolen
try to go to store where they sell same cameras and finilize it there. or use software called: CDRoller
Hi8 to dvd
Greetings ocean view,
My suggestion would be to find a retailer who transfers video tape to dvd. They use an actual machine to do this and it should recognize your tape. This might solve your problem.
I hope this helps!
Sincerely,
Dorothy
Go Ahead. Use Us.
2helpful
2answers
Drivers!
I searched Sony's website and this is what came up with your camera model:
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
    Note: If the your camera or camcorder is not recognized by the computer when connected, you may need an updated driver. Check the Updates tab below to see if any updated driver is available.
  • Starter and 64-bit versions of the Windows Vista and Windows XP operating systems are not supported
  • Most versions of XP and Vista are not 64-bit but you might be one of the few "unluckies"
    Hope this helps you out a little.
    Old tapes don't play
    I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
    Top Polycom Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
