Home Logo
Anonymous Posted on May 07, 2013
How is air supply regulated in wood burning stoves?
austin lighthart
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Dec 08, 2014
austin lighthart
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1300
Points
6
Agreed with the answer above. every wood stove will have some type of damper located somwhere on the stove. regulating your air flow controls heat output and burn time!
Derek Nickerson
Level 1:
New Friend:
Problem Solver:
  • Contributor 3 Answers
Derek Nickerson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
1558
Points
9
Usually their is air flow slots on the clean out door
Anonymous
Level 1:
New Friend:
  • Contributor 75 Answers
  • Posted on May 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
75
Questions
65
Helped
34922
Points
87
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
1helpful
Just bought a house with a Gibraltar SCR stove in it. I want to use this thing, but have never owned a stove and don't know how. What fuel? How to set the fuel in the stove, etc. Can you help?
Gibraltar makes coal, pellet and wood stoves. Stoves that burn wood pellets have a hopper and feeder auger that feeds pellets into the burning chamber. They also require electricity to work. From what I read online you should be able to burn wood in the stove but I believe the coal stoves have a smaller burning chamber.
tip
Outdoor Wood Stove Hot Air or Hot Water
You're getting a new wood stove and you have many decisions to make. Other than brand, you need to decide whether you will use hot air or hot water to get the heat from the wood stove to the living space.
If you have a hot water heating system already installed then you obviously need to have a water stove. If you are thinking about what to install in a new home or already have hot air then you need to consider what will be the best option for you.
Now if you are installing a new system then you want to go hot water. That is by far the best way of heating and will be the best way to heat using an outdoor wood stove. Hot water heating is one of the best ways to get great heat transfer from the fire to the water to the air.
If you have hot air heat and want to heat with wood then you can install a wood hot air furnace, and set it beside your existing furnace. The ductwork will have to be reworked to get the heat from the wood furnace to the existing ductwork. Or you can install a coil into the ductwork on the supply side of the furnace, for the water to run through from a hot water wood burner. This is probably the best way to heat if you have a hot air furnace. Installing the hot water coil is a very simple process and the piping is fairly easy to hookup.
Hot air wood furnaces are almost always a inside the structure appliance, which means that you have the mess of the wood and the ashes inside. This dust and dirt mess is something that is much better kept outside where it can be cleaned up much easier.
Bottom line here is that you want to use a hot water wood burning stove if you can. You will be much happier with the heat that you get from burning wood.
on Dec 08, 2009 • Heating & Cooling
tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 • Heating & Cooling
1helpful
My pellet stove is turning my mobile home into a sauna! How do we turn the auger and heat down.
A corn burning heat stove is designed to burn shelled corn.
Corn burns hotter than wood. Corn is an annual, renewable resource that is in plentiful supply. Our stove will be delivered in about two weeks and we will have about 120 bushels of corn outside the back door for a ready supply.
We will load the hopper with a five-gallon bucket of corn once every 24 hours during the coldest days. There is a heat regulator so we can adjust it for warmer or colder days. Our home is a fairly open design and with the stove in a central location, it will easily heat all rooms. No chimney....it is direct vented outside, and it didn't raise our insurance as a wood-burner would.
We will use a minimum of propane for cooking and heating water.....less than 250 gallon a year. No cutting down trees, chopping wood or buying loads of wood.
Oh yeah, another thing.......we needed a base for the stove.....DH works at a large home improvement store and brings home boxes of whatever is being discontinued at the moment.....he happened to bring home a variety of marble sample blocks.......they are going to make a beautiful base.
Dec 01, 2016 • Pool & Spa
2answers
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 • Home
1helpful
2answers
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
1helpful
How do i keep this fire alight
How to light a wood stove fire
Stove Help & Advice Home
There are many ways to light a fire in a wood stove. There is no one right way to do it and I am sure that all the stove owners out there will have their own individual ways of lighting fires that have developed over the years.
This is one way to light a woodburner. Ensure that the stove firebox is not full of ash - remove ash if necessary using a suitable metal container. If the stove is a multifuel stove where the only air supply is from beneath the stove grate then you will need to make sure that the grate is clear from ash and that the ashpan is empty (or at least that the ash in the ashpan is not obstructing the air flow to the fire).
Open the bottom air vents of the stove and open the flue damper if you have one. Some people use firelighters but personally I think that they smell bad and are uneccessary.
Start with some pieces of newspaper and scrunch them into loose balls. Some people tie them into knots or other shapes which is fine as well. I have tried this and it takes much longer than just scrunching the paper into balls.
I use about 8 full sheets of newspaper to light the fire. It is possible to use much less paper, but if there is no need to conserve your newspaper supply then my opinion is that you might as well be assured that the fire will light by using a little bit extra. Pile the balls of newspaper in the centre of the firebox.
Get some kindling. If you do not have some already prepared then use dry seasoned pieces of firewood. Softwoods or light hardwoods are best so pine, beech, or ash would be fine. Use a hatchet to chop the wood into some small pieces roughly 10mm square. The sizes do not have to be very precise and I would not recommend measuring each bit! Lay around 6 small pieces on top of the newspaper in different directions - rather like the game pickup sticks. The idea is that air and flames should be able to get to each piece of wood. Now lay a few larger 30mm and 40mm square pieces on top.
Light the newspaper in a couple of places at the bottom and when they are going close the door of the stove.
Once the wood has caught alight and the fire is going well inside the stove you can put some larger pieces of wood into the firebox. Place them gently on top of the fire. Do not fill the firebox with wood - I would recommend burning around 3-4 large pieces of wood at a time. At this stage you can turn the air supply down a little but aim to maintain good flames whilst not letting the fire smoulder.
If you have air vents at the top of the stove then close down the air vents at the bottom and open those at the top. You may need to do this gradually as the fire develops.
A novel way of lighting a fire is in a top-down direction. You start with the bigger pieces of wood, then on top of them put the smaller pieces of kindling and on top of that lay some newspaper balls. Everything is done in the same way as in the bottom-up method discussed above but just in reverse order. Light the newspaper and the fire will work it's way down. Surprisingly this is a remarkably good way of lighting a fire - why not give it a try.
If you are still having troubles lighting your fire, you can always purchase a Phoenix firelighter. No newspaper or kindling is required and can have your stove roaring away in 2 minutes. The Phoenix Firelighter has revolutionised lighting of solid fuel fires whether it be wood for coal and only costs 1p per fire.
Things not to do
Do not use paraffin, ethanol, petrol or similar to help you light a stove. Here is an article about someone who did
Do not leave the stove unattended whilst it is being lit, especially if you have cracked the door or ash pan open to give it that little boost of air.
Source: stoves online dot co dot uk
Aug 25, 2014 • Home
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
