Try pressing these buttons for 5 seconds, it will unlock.
OR
Press the "menu" button until you see"CHILD LOCK: ON" appear in the display. (if nothing is
pressed within 10 seconds following this the menu will close and it will default
to program in the display)
Once you see what I just mentioned in the display
press the "select" button until"CHILD LOCK :
OFF" appears in the display.
Finally by pressing the"start/pause" button the key symbol should
disappear confirming you have successfully unlocked..
Pl click if helped.
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Turn program selector to "off". Turn
selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start /
pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower
right of the front panel is a 6" / 15mm cover. Near the bottom of this cover
is a small hole. Insert a piece of wire into this hole, and push in gently.
While pushing, turn the cover clockwise,
it will came off.
The door release is a narrow white plastic strip
hanging down on the right; Pull down on this strip while pushing in on the
door, the door lock will release.
Pl click if helped
