Recently, my unit started cycling on and off about every two minutes or less. It will not run continuously in either heat or cooling stage. This causes the unit to run practically all day to keep the set temperature.
You say heating or cooling? DO you mean the INDOOR, Out Door, section or both? Is this s heat pump (if so it will have a setting on the thermostat that is labeled E or EMR or Emergency Heat).Do you use Gas heat? ELectric Heat?
Discribe your thermostat please. I will post back.
