20 Most Recent Hobart Handler 140 Mig Welder Questions & Answers
2answers
Wire feed is sticking when
Cleanliness is important when it comes to Mig welding. Any rust, dirt, dust, oil is liable to be deposited in the whip liner. If it's just a dirty liner you can try cleaning it with a solvent that doesn't leave an oil deposit (electric motor cleaner, brake cleaner, that sort of thing) compressed air and flexing of the whip.
Make sure your whip hasn't been crimped, if it has then no amount of cleaning will restore it to operation.. a new liner is the only reasonable answer.
It's possible that a bad tip can cause feed issues. Miller type tips are the worst, in my experience, sometimes you just get a tip that will weld to the wire when the current passes between them. I've worked in shops where I might go through three tips in five minutes and then hit one that would last all afternoon. If the wire sticks and you can hold the gun up and rotate your wrist and you feel a 'pop' and the wire jumps out of the tip then just change the tip out. Excessive roller pressure with a tip that's sticking to the wire can really make trouble for you. Nozzle dip is your friend sometimes with tip sticking issues.
Copper clad wire is not particularly friendly to liners, the copper is liable to flake off in the liner. I use bare wire, I bag the wire in a plastic bag on the feeder and I wrap a scratcher pad on the wire just before it goes into the feeder and I find that I have few feed issues. Wire that has even a trace of rust should be discarded as it will both fill your liner with rust and give poor quality welds.
lp
11/13/2019 6:24:07 PM • Hobart Handler... • Answered on Nov 13, 2019
2answers
My daughter plugged welder into
The weld wiring burning doesn't meant the transformer is good, it only means you have shorted hot to ground and thats what happens when hot touches ground it heats and melts. I would start by looking for a schematic for you welder. Check and making sure your getting good power to the power supply, relay(s) first. Also you can ohm out the transformer and check for the proper resistance but without the schematic/wiring diagram I can't say what the specs are. Normally on these the power comes in to the switch and then to the relay(s) which send power to the fan, and then splits to the trigger which allows power to the transformer, wire feed motor etc. But without the diagram your just shooting in the dark.
8/10/2016 9:15:35 PM • Hobart Handler... • Answered on Aug 10, 2016
2answers
My Hobart Handler 120 needs a .045 wire drive Wheel.
Locate your locale Hobart welding distributer, or contact hobart, the are nice people and will give you all the avice you need.
5/2/2016 2:50:34 PM • Hobart Handler... • Answered on May 02, 2016
2answers
My Hobart 140 will not get hot enough to make a weld. It will feed out the wire, make a spark, and the flux core wire will melt on top of the thin rouaght iron square tube fence but it will not melt
Hi:Sounds like you have the wrong polarity in your machine. If you are using flux core wire, make sure to connect your ground clamp to the positive side and your gun to the negative side. Dial the right voltage and wire speed according to wire size and metal thickness.Let me know if this help.Regards,D.S.
5/2/2016 2:47:29 PM • Hobart Handler... • Answered on May 02, 2016
How would one attain a replacement for the main circuit board
The main control circuit for the welder has gone bad....cost about $198.
Might be better off to buy a new welder. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
12/22/2015 2:43:13 PM • Hobart Handler... • Answered on Dec 22, 2015
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
9/17/2015 7:42:03 PM • Hobart Handler... • Answered on Sep 17, 2015
I have a hobart Handler 135 and it won't feed the wire correctly. At first it will feed about 6 " of wire then it goes down to about an inch at a time then it will just click. If you wait awhile it wi
If you completely remove wire from unit does it still slowdown and stop when you pull trigger?
If yes, then 2 most common problems are
A. Thermistor @ position PTC1 on circuit board
B. Drive Roller Motor
To diagnose, locate thermistor @ position PTC1 in upper middle part of circuit board.
It's yellowish round and about 1/2" in diameter.
Jumper Accross the 2 leads, use a small insulated screwdriver or meter probe.
1. Pull trigger on gun, when motor slows or stops then jumper the leads, if it speeds back up then it's the Thermistor
Replace with a Raychem RXE 1.85A @ 72 v
Or comparable, try EBay
2. If no change, isolate motor by removing the 2 leads and connect a 9-12 volt DC battery source, does motor spin? If not then motor is problem. If motor spins and is constant then additional troubleshooting needed, next possible issues are bad resistor or scr
7/3/2015 6:38:24 PM • Hobart Handler... • Answered on Jul 03, 2015
2answers
I have a hobart handler 140. wire feeds ,no weld
check main contactor or diode bank.
2/20/2015 8:27:02 AM • Hobart Handler... • Answered on Feb 20, 2015
Hobart handler 140 no power
What have you tried so far?
1/16/2015 10:13:54 PM • Hobart Handler... • Answered on Jan 16, 2015
I need Q1 transistor for 135 hobart welder
The transistor is mounted on the main circuit board, you cannot buy the part from Hobart or Miller, they only sell the complete circuit board. If you can read any part numbers from the transistor you can purchase the part from a electronic parts supplier.
7/23/2014 11:17:02 PM • Hobart Handler... • Answered on Jul 23, 2014
I have a problem with a jerking motion while Im
I have found that keeping the gun lead as straight as possible fixes this problem. Also it is sometimes recommended to use one tip size bigger when welding with flux core wire. My last spool was radnor flux core wire .030, and a .035 tip keeping the lead as straight as possible and it welded extremely well. If that doesn't solve it you should take everything apart and clean it / blow it out with compressed air.
6/6/2014 11:39:30 AM • Hobart Handler... • Answered on Jun 06, 2014
Miller syncrowave 300 no power light and no weld power however have 480v input fan runs and can hear gas start when foot petal pushed
bad computer-its an authorized dealer thing-you can pay 1-200 to get it figured out or buy a HF flux core welder for same price. yeah-Im all blue in my shop and I said HF... i would pay the miller dealer to get it fixed.
5/9/2014 6:02:58 AM • Hobart Handler... • Answered on May 09, 2014
3answers
Wire spool with not turn continuously while I am welding. It turns and stops, turns and stops. What can I do to fix the problem?
should be adjusters where the wire feeds out to the hose... adjust those. couple of youtube videos online should help you out
5/9/2014 5:59:30 AM • Hobart Handler... • Answered on May 09, 2014
The first thing to check would be to see if you have open circuit voltage at the weld output terminals when you push the pedal. Make sure the high frequency is off if you are going to to check with a multimeter. After that if you do have OCV but no high frequency to start the arc, try it in start and in continuous. When you put it in continuous it bypasses a control relay. Also check the HF points to make sure they are clean and gapped to about ten thousandths.
4/10/2014 12:47:58 PM • Hobart Handler... • Answered on Apr 10, 2014
My motor on my hobart handler 135 is not working to make the wheels roll to feed wire. I disconnected it at the connectors and tested it and was not getting any readings on my meter as if it was not g
Make sure the trigger switch is applying power to the motor. If there is no reading when you checked for OHMS then the motor is open. You'll have to get a new one.
1/16/2014 10:19:49 PM • Hobart Handler... • Answered on Jan 16, 2014
L bought a hobart 140 two days ago, welded about 10 feet of wire with it .now it only feed wire on three out of the five settings
Check the selector switch with an ohm meter. Unplug the unit, ground to chassis and probe the contacts while turning the switch on and off.
12/8/2013 12:26:36 AM • Hobart Handler... • Answered on Dec 08, 2013
Hobart 175 ,pull trigger relay clicks have 24
If the machine has diodes check them. Also if it has a bridge rectifier check it. My 120 would not feed wire and the bridge rectifier was bad.
10/26/2013 1:24:51 AM • Hobart Handler... • Answered on Oct 26, 2013
Hobart Handler 140 Mig Welder Logo
146 questions posted
Top Hobart Welding Tools Experts
Sean Wright
Sean Wright
oneStan
oneStan
Kardoc
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
View Most Popular
  • Hobart Welding Tools
Most Popular Question
hobart handler 120 needs 045 wire drive
  • Welding Tools
