20 Most Recent Carrier 38BRC036 Air Conditioner Questions & Answers
Carrier Celesta R - error
E-4 ..........short of asor no gas/E4 is an "Abnormality of Outdoor Unit."Find leak and arrest it. Recharge gas.
5/10/2015 3:55:27 PM • Carrier 38BRC036... • Answered on May 10, 2015
0answers
3answers
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
12/12/2014 10:57:01 PM • Carrier 38BRC036... • Answered on Dec 12, 2014
What is the number of tons for a carrier air conditioner model number 38EB030300?
EB030 Indicates 2 1/2 ton (24= 2 ton 36= 3 ton 42= 3 1/2
8/12/2014 6:54:13 PM • Carrier 38BRC036... • Answered on Aug 12, 2014
Error E4 in 53 QH12-B
check indoor fan motor
5/13/2014 12:46:14 PM • Carrier 38BRC036... • Answered on May 13, 2014
0answers
I have a carrier furnace
code 33 LIMIT OR FLAME ROLL-OUT SWITCH IS OPEN - If open longer than threeminutes, code changes to #13. Flame roll-out switch requires manual reset.Check for: - Dirty filter or restricted duct system. - Loose blower wheel.- Defective blower motor or capacitor. - Defective switch or connections.- Inadequate combustion air supply (Flame Roll-out Switch or fuse link open).- Open Flame Roll-out switch, or fuse link. Manual reset or replace.
11/13/2013 5:55:27 AM • Carrier 38BRC036... • Answered on Nov 13, 2013
0answers
Motor blade not moving, motor
sounds like the fan motor is at fault , 1 it could have bearing problems 2 the capacitors if it has are at fault , to correct check fan with out power to see if it runs free if it runs smooth then i suspect the capacitors are at fault , you will need a megger to check both items , make sure you check that they both accept a charge of 500 volts and that they discharge , if one does not , then change for a knew one ,
10/20/2011 9:50:34 PM • Carrier 38BRC036... • Answered on Oct 20, 2011
Carrier 38BRC036 Air Conditioner Logo
70 questions posted
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Carrier Heating & Cooling
Most Popular Question
carrier celesta r error
  • Heating & Cooling
