Colors are tinted green
SOURCE: TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
SOURCE: Mitsubishi WS-55819 has double vision screen with
Sounds like bad convergence IC's; this set uses two STK-392-570 IC CHIPS; both should be replaced and the blue 3.9 ohm resistors in front of them should be checked. Get someone who has done this repair on this kind of set before--it is usually not something for a do it yourself person; the middle pc board needs to be removed to safely replace the chips; then the set needs to be adjusted in the regular and HD modes. If this is helpful, give me a vote. if you need more direct information email me: [email protected]
SOURCE: green tint on screen
2006 Model Year SXRD Televisions:
Models: KDS-50A2000, KDS-55A2000, KDS-60A2000, KDS-R60XBR2, KDS-R70XBR2
As part of the Sony commitment to quality, Sony is announcing
that it is extending the limited warranty (parts and labour) in Canada
on the optical block of 2006 model SXRD televisions (models listed
above) until June 30, 2010 , regardless of purchase date. This
extended warranty does not apply to replaceable projection lamp and
other parts that may be used in the televisions.
Sony is also announcing that for any owner of these model SXRD
televisions who paid out-of-pocket expenses on or before December 31,
2008 for an estimate or repair service to replace the optical block,
Sony will reimburse the customer by mail for the cost of the optical
block and the labour expense to replace it, subject to certain
conditions. To receive reimbursement, please follow completely the
directions on the claim form for reimbursement attached HERE; all claims must be postmarked by January 31, 2009. See the claim form for complete terms and conditions.
In addition, for any customer who later experiences this issue
on one of the affected models, Sony will cover the cost of the optical
block repair (parts and labour) at no charge through June 30, 2010.
For customers currently under a 3rd party extended warranty or
service contract, please contact your third party service provider
directly. This offer is available only to end-user consumers who
purchased their affected television at retail in Canada and is not
transferable. The offer is not available to providers, obligors,
underwriters, or administrators of performance service plans, buyer
protection plans, or other warranty or extended warranty programs.
This offer is not part of the Sony limited warranty or Sony Care
extended warranty plan.
For further details please contact Sony Canada's Customer Information Center 1-877-899-7669
All other terms of the Sony limited warranty or Sony Care extended warranty plan, as applicable, continue to apply.
Top
SOURCE: the red, green and blue colors do not line up correctly
This set is fairly easy to fix for this trouble. A AV48p30 usually takes me about 40 minutes to fix for this problem.
It uses two of the STK-392-110 convergence chips. The repair involves two things--getting at the chips (easy) and being able to unsolder them and replace them.
You can buy almost everything you will need on Ebay for under 30 dollars (I can tell you who to look for there)
Most shops are going to get 300 or more for this kind of repair so if you or someone you know can do it you can save a lot of money.
I can tell you how to get at the chips and also everything you will need to do the repair.
If this information has helped you rate this solution as I do this here for free.
If you want the detailed instructions let me know and I will post them here for you.
SD TECH
SOURCE: Has bad color,no greens and red tint.
Change the coolant in the CRTs. The blue and green get contaminated and cause the red to become dominate. You can verify this by looking into the lenses of the CRts with a flashlight and you will notice what looks like bacteria in the lenses indicating that the Coolant needs replacement. You can then get the CRT coolant kit at www.tvrepairworld.com which has the coolant and the CD with instructions for Phillips Tvs.
