Possible ways to remedy this problem:
problem of weak beverage
solutions:
1. Filter Type-BUNN paper filters must be used
for proper extraction.
2. Coffee Grind-A fine or drip grind must be used
3. Sprayhead-A six-hole stainless steel spray-
head must be used for proper
extraction.
4. Funnel Loading-The BUNN paper filter must be centered in the funnel and the bed of ground leveled by gentle shaking.
5. Water Temperature- Place an empty funnel on an empty
dispenser beneath the sprayhead. Initiate a brew cycle and check the
water temperature immediately below the sprayhead with a ther-
mometer. The reading should not be less than 195F (91C). Adjust
the control thermostat to increase the water temperature. Replace if necessary.
