HP Pavilion dv6000z Notebook Logo
Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is cs3 Compatible in Vista Home Basic
Using Vista Home Basic. CS 3 cannot be installed fully. Installed portion can not be removed. Need help
Anonymous
Level 2:
Novelist:
  • Expert 148 Answers
  • Posted on Mar 04, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
148
Questions
0
Helped
44098
Points
309
Did you run the install as an administrator? Try right-clicking on the setup icon of the program and choose "Run as administrator" Most programs have repair options during installation, try repair if you can. If you dont try to remove. In ALL cases you must do this as an administrator under Vista.
2helpful
2answers
I have a emachine E625 i installed the driver and i tried using skype but it doesnt register the camera
The message you receive means that Skype does not support the video format being generated by your camera. This can usually be fixed by downloading Splitcam. http://www.splitcamera.com/
1helpful
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Windows Vista business & Home Basic
No you can't downgrade once Vista business is installed, what i do recommend you do is when Vista business asks you for the product key, if you input "your" key for home basic it should theoretically install home basic for you as most of the install DVD's are multi installers (basic, premium, business and ultimate)
See if that helps you.
Regards
2helpful
D845GLVA - vista Home Basic - Display drivers
sorry no vista support for this board u have to get an ext graphics card for vista support nvidia ,ati , all are good
pls see this ur self ur on board vga doesnt support vista
http://www.intel.com/support/motherboards/desktop/sb/cs-008326.htm
pls rate me fixya for this if u like
OS/Drivers incompatible Acer Extensa 4420
i can solve this easy,i had the same problem when i installed xp pro on my comp.it should be easier now than when i did it.first go to microsoft.com,go to their support and downloads section,then go to drivers and have them show you all the drivers you need ,then download them and install them,if that does'nt work let me know and i'll get you a program that will work.
I'm trying to installing my software ( resume maker edition career) the system is let me know this software is not compatible for window vista. can you help me let me know what kind of program I need to...
Hello
Microsoft had change backward compatability when it come to produce vista for end user, so most of the softwares developed for the earlier softwares did not run on windows vista, although i don't know which type of vista you are using, but vista home basic support some of the obselete softwares. Why not try to use vista home basic and see wheather you will succeed. Or I will say you download the softwares from the developers site which is compatible for vista OS.
Enjoy.
Yarima
Computer does not recgonize my hp printer, running windows vista home edition 32-bit oprerating system
firstly:
  • have you installed the driver for the HP printer,if not do so.
  • is the HP printer Vista compatible, it should say in the literature that came with it .if its an older printer probably not compatible.
  • follow the installation directions fully ( plug the usb cable in when it asks for it etc).
  • use a different usb cable as it may be faulty.
  • check the usb port with another item such as a memory stick to ensure it is working or use another port.
  • remove any printers installed prior to trying to install HP printer and reboot the system.
hope this is of help to you
Terry
2helpful
2answers
Vista and Panasonic PV-GS300
You can download MotionDV STUDIO Ver.6.0 at the following link. That version is compatible with Vista Home Premium and Basic.
http://panasonic.jp/support/global/cs/soft/download/motionDV60E_LE_1.html
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
